Boat weight rating question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 26th, 2011, 09:52 PM   #1
IPLUMB
IPLUMB's Avatar
Default Boat weight rating question
OK, When the label in a boat says 4 persons OR 570 lbs? Does that mean if I have three people in the boat that weigh over 570 lbs that I don't comply? Confused.
IPLUMB is offline   Reply With Quote
Old July 26th, 2011, 09:54 PM   #2
booblinker
Sore and Tired 24/7
booblinker's Avatar
Yes, 4 person or 570 pounds, whichever comes first.
Old July 26th, 2011, 09:55 PM   #3
HVYRTFT
Reed my teef
HVYRTFT's Avatar
correct.
Old July 26th, 2011, 09:57 PM   #4
Trendsetter
Trendsetter's Avatar
Send a message via AIM to Trendsetter Send a message via Yahoo to Trendsetter
first this should be moved but here ya go simple and straight forward for you
the old coast guard standards was from back in the 50's or 60's and the AVERAGE adult weighed ALOT LESS... using your numbers around 140 lbs per person. They are actually upping those numbers shortly if it hasn't been done already to around 180-190 per person.
so in answer to your question yes if you are OVER the weight you are out the safe operation of that vessel and if something happens its on you not the boat maker
Trendsetter is offline   Reply With Quote
Old July 27th, 2011, 05:36 AM   #5
IPLUMB
IPLUMB's Avatar
Can you be ticketed for it?
Old July 27th, 2011, 05:51 AM   #6
Trendsetter
if they want to be a prick about it yes you can get a ticket for unsafe boating.
guessing on a boat that small though this is a none issue, as they would have to make each of you step on a scale to prove your over the limit. normally its a head count and make sure your not over the recommended hp rating
Old July 27th, 2011, 06:02 AM   #7
Immortal
NO RELIGION WAT!
Immortal's Avatar
Find thinner friends.
Old July 27th, 2011, 07:04 AM   #8
kickstand
circling the drain
kickstand's Avatar
Yes.
be less fat.
kickstand is online now   Reply With Quote
Old July 27th, 2011, 08:57 AM   #9
bdd1469
bdd
bdd1469's Avatar
Yes ,but if you have a throwable cusion and plenty of life jackets,you will probobly be fine.
Old July 27th, 2011, 08:59 PM   #10
IPLUMB
IPLUMB's Avatar
Yes.
be less fat.
It not me its my father in law and another fishin buddy.
Old July 27th, 2011, 09:15 PM   #11
DuffMan
Your Message Here
DuffMan's Avatar
The weight rating describes the boat's ability to carry weight - people or otherwise.
If boat appears overloaded to a point that safety is affected (i.e. riding dangerously low in the water) you can be cited - regardless of number of occupants.
Page generated in 0.25273 seconds with 55 queries
