99 f-150 4.6 motor /frame swap 5.4 body - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 26th, 2011, 07:47 AM   #1
jeepman2010
jeepman2010's Avatar
Default 99 f-150 4.6 motor /frame swap 5.4 body
i bought a truck that a swap was started 99 rolled truck 4.6 auto installed a 99 5.4 body .harness from 4.6 motor stayed harness in 5.4 body stayed ,pcm and dashclusted and steering column from 4.6 installed in 5.4 body.tranmission is not working properly wont shift into overdrive or work properly transmission tech ran diagnostics on it said it was in the electronics/wiring DOES ANYONE HAVE ANY ANSWERS PLEASE HELP
jeepman2010 is offline   Reply With Quote
Old July 26th, 2011, 09:00 AM   #2
Toivo
Feel lucky?
Toivo's Avatar
yes.
use the right parts intended for the application.
/end thread.
Old July 26th, 2011, 09:23 AM   #3
masterbeatty
masterbeatty's Avatar
so you have a
4.6 with the 4.6 engine harness but the cab harness is 5.4?
the cab harness is the same, the dash and column are the same the difference is the trans, the 4.6 trucks had 4r70w while the 5.4 had a e4od or a 4r100 depending on the year and 2wd or 4wd, but if you swapped the whole harness and the computer i see no reason why it wouldnt work.i am sure the trans harness is different to read different sensors
Page generated in 0.20669 seconds with 32 queries
