Anyone know scrap place that pay higher $$ for heavy iron cast? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 25th, 2011, 02:18 PM   #1
MilwaukeeF350
Dan
Default Anyone know scrap place that pay higher $$ for heavy iron cast?
Well we have 5 Nissan 60 Forklift so they weight 9-11K pounds.
We tried 3 Scrap places they refused accept counter weight but it not concrete inside it FULL of IRON CAST.
They offer $160-200 a tons. 4 years ago they offer $400 a ton for those but for normal scrap/ cars it was $325-375 a ton.
5 forklifts is in Redford but we can travel if they pay more $$.
Old July 25th, 2011, 03:04 PM   #2
Renegade II
Coil springs are for pens
Renegade II's Avatar
http://www.rifkin-co.com/saginaw.html
Old July 25th, 2011, 03:24 PM   #3
MilwaukeeF350
Dan
Originally Posted by Renegade II View Post
That one we was think of go. They offer $250 a ton but must have rubber tires off.
Old July 25th, 2011, 06:43 PM   #4
mideerslayer
NEVER GIVE UP!
mideerslayer's Avatar
Cant you cut of the side to show whats in side?
mideerslayer is offline   Reply With Quote
Old July 25th, 2011, 06:49 PM   #5
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
it would only take 4 days and $250 worth of cut off wheels.....
Old July 25th, 2011, 06:51 PM   #6
Wheelman
Extreme Mudder
Wheelman's Avatar
i Take everything to Regal Recycle in Howell. I don't know how much they would give you but call them. www.regalrecyclers.com
Wheelman is offline   Reply With Quote
Old July 25th, 2011, 06:55 PM   #7
welderboyjk
KMR or Kalamazoo Metal Recyclers will take anything. Probably too far away from you to be worthwhile though. They do have trucks on the road occasionally. Give them a call, maybe they'll be somewhere near enough to pick up.
welderboyjk is offline   Reply With Quote
Old July 25th, 2011, 07:00 PM   #8
zook94
Resident Jerkoff
zook94's Avatar
Location: Saginaw, Michigan, USA, North America, Earth, Milky way
You could have the recycler use their cutting torch to open up the counter weight to see whats inside, but you would get more money if it was pure cast iron to separate it, as clean cast is much more than cast incorporated into other things.
zook94 is offline   Reply With Quote
Old July 25th, 2011, 07:28 PM   #9
CatRover
CatRover's Avatar
ive seen a few forklifts in west michigan recyclings yard in muskegon. try giving them a call. 231-773-7582. they will work with you.
CatRover is offline   Reply With Quote
Old July 25th, 2011, 07:48 PM   #10
95beast
Im Farva Bitches
95beast's Avatar
I go to Genesee Recycling in Flint they pay pretty good
http://dev.soave.com/core/diversified_genesee.php
95beast is offline   Reply With Quote
Old July 25th, 2011, 07:53 PM   #11
deerebowtie
Unchained
deerebowtie's Avatar
rob the orbital valves and hydraulic cylinders to sell here on the cheap. no weight lost and you'll make more $$ Dan
Old July 25th, 2011, 08:56 PM   #12
dmcjeep
dmcjeep's Avatar
rI took mine to Padnos in Holland and tey paid the same as regular scrap. Docked me a little for the tires but it was not much. Need to drain the Hyd. fluid though.
dmcjeep is offline   Reply With Quote
Old July 25th, 2011, 09:20 PM   #13
MilwaukeeF350
Dan
Sound good idea.
Problem why Boss rid of it. Buy out biggest company that went out of business They didn't do maintain on fleets. They run straight to ground. Forklifts look nice but had no air filter on engine or not chg oil on time. No compression. One running but extremely bad blow out out oil cap.
one is this
Old July 26th, 2011, 08:02 AM   #14
Hunter9
Not Right!
Hunter9's Avatar
Dude, have you ever taken an engrish crass?
Hunter9 is offline   Reply With Quote
Old July 26th, 2011, 08:20 AM   #15
Muttly
Muttly's Avatar
He has taken alot of American Sign Language classes and does pretty good.
Muttly is offline   Reply With Quote
Tags
wat
Page generated in 0.28288 seconds with 67 queries
