Ranger - Page 4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 16th, 2011, 04:43 PM   #61
robbietap
Originally Posted by Strangler View Post
I
Awesome build. I would outboard those rear shocks tho. My (very) limited experience with airshocks is that they can be overpowered by leverage very easily. Being mounted that close to the center of the axle is going to make your swaybar working overtime.
I have been stairing at them for a while, i may try to push them out a few inches, gonna take some tube work tho.
robbietap is offline   Reply With Quote
Old December 16th, 2011, 08:52 PM   #62
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Is there any room for a cross member to tie those two front shock mounts together? Over top would be best but I think you could go under the motor without too much work. That would help with the rotational force that those tall towers are putting on the frame, and you probably could make an engine skid out of it.
Old December 16th, 2011, 09:52 PM   #63
robbietap
Yeah, i still have quite a bit of tube work to finish on the front end. Got some steel showing up Monday, I plan to bridge over the motor. Maybe get some pics up next week.
Old December 17th, 2011, 07:16 AM   #64
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
I
they way he has them mounted right now I'm willing to bet they dont work at all...they will be fine for straight up and down, but they will not dampen any type of flex
Old December 17th, 2011, 08:29 AM   #65
robbietap
I understand the leverage involved, after I build my control arms and get a chance to cycle the rear I may infact push the lower mounts out. As they sit I estimate they will only travel about 8"-10" unless the entire axle is comressing, which should be nice and squishy. Again, after I get a chance to cycle the axle I may move the lower mounts outward, just gonna take a bit of work on the upper frame for clearance.
Old December 17th, 2011, 09:05 AM   #66
Christmas Cookie
to get the most out of your shocks they need to be mounted as far out as you can go...otherwise you are moving the axle without dampening it...if your axle only moved in straight liner compression/rebound it wouldn't matter, but an axle doesn't move that way
Old December 17th, 2011, 09:27 AM   #67
robbietap
I get what ur saying. I get it. I get it. I understand what you mean. I.
Old December 20th, 2011, 01:29 PM   #68
robbietap
Shaved the rocker as Ford added more to it than needed on the Ranger cab, have another photo from the underside that is not co-operating at this time. Anyone ever flattie a Ranger fender? Thinking about tubing from my rocker step up and not quite flat, but high enough to come down a few degrees and over to what will be the front bumper with some 1.5 round tube. Then fitting some 18 gauge from the tube back into the fender.
Old December 20th, 2011, 03:27 PM   #69
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
VERY nice work. Thanks for sharing.......
RIP FULLSIZE4LIFE
Old December 21st, 2011, 10:30 AM   #70
Offroadian
seasoned
Looks good.
How about a pic of the floor, with the door open.
Offroadian is offline   Reply With Quote
Old December 21st, 2011, 12:14 PM   #71
robbietap
Originally Posted by Offroadian View Post
Looks good.
Like this? I plan to trim it out with some Rubber Edge Trim from Mc-Carr.
Old December 21st, 2011, 12:17 PM   #72
Strangler
Strangler's Avatar
Very nice!
Old December 21st, 2011, 07:57 PM   #73
robbietap
Got some parts for my rear diff and front diff from my buddy MM Dave, had some 5/8 round bar lying around and did some work on the 60 cover, just needed to protect the bottom as the upper end of the cover is above the Artec skid plate.
Old December 22nd, 2011, 06:27 AM   #74
Offroadian
seasoned
Yes.
That looks great.
Old December 22nd, 2011, 10:33 PM   #75
BLZR
Welds look killer!
BLZR is offline   Reply With Quote
Old December 23rd, 2011, 04:40 AM   #76
robbietap
Thanks BLZR
Old January 15th, 2012, 05:59 PM   #77
robbietap
Fabbed up a bumper and some extraction points...
Old January 15th, 2012, 06:07 PM   #78
robbietap
Bling.
Old January 15th, 2012, 06:09 PM   #79
robbietap
I have no more room for pics, what options do I have?
Old January 15th, 2012, 06:47 PM   #80
robn69
robn69's Avatar
photobucket
http://photobucket.com/
robn69 is offline   Reply With Quote
Page generated in 0.37730 seconds with 84 queries
