Ranger - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 20th, 2011, 07:21 PM   #41
robbietap
Originally Posted by Ford rules View Post
Never seen coilovers mounted inside the frame rails before.
Looking good though!
I am sitting at 17" at the upper mount and will be able to spread to 32" at the axle, I plan on running a currie TJ sway bar.... I think it will work out well... I am going to run Fox 2.5 Air Shox. on all 4 corners on this project.
robbietap is offline   Reply With Quote
Old November 20th, 2011, 07:22 PM   #42
robbietap
Originally Posted by High Center Hancho View Post
this is kind of neat...
Thanks.
Old November 20th, 2011, 10:40 PM   #43
Offroadian
seasoned
Little diferent approach.
I like it.
Offroadian is offline   Reply With Quote
Old November 21st, 2011, 05:12 PM   #44
robbietap
Made up rear shock tabs and some mock shocks.
ID:	86089   Click image for larger version
ID:	86090   Click image for larger version
ID:	86091   Click image for larger version
Old November 22nd, 2011, 06:15 PM   #45
robbietap
Got the upper mnts. complete and welded in a sway bar tube, gonna run an 36" Currie.
ID:	86117   Click image for larger version
ID:	86118   Click image for larger version
ID:	86119   Click image for larger version
Old November 24th, 2011, 01:10 PM   #46
robbietap
Front shock towers tacked in place, waiting until I get my front four link brackets welded and cycle my front end prior to finish welding due to some good advise. Also cut out the tubing that was run into the cab, it was in the way.
Old November 30th, 2011, 06:07 PM   #47
kmanxj5011
kmanxj5011's Avatar
Looks good tap! I gotta get over and check it out again. You working third shift?
kmanxj5011 is offline   Reply With Quote
Old December 1st, 2011, 06:08 AM   #48
robbietap
On days now, let me know when you plan on swingin by I'll fill the fridge
Old December 1st, 2011, 06:43 AM   #49
kmanxj5011
kmanxj5011's Avatar
ok will do, Lexi is working second at ventra so if it was during the week it'd be me and the boy during the week. Have to sneak over on a weekend though if the fridge is gonna be stocked
ill let ya know. NOW GET THIS THING DONE!!!!!
Old December 14th, 2011, 01:18 PM   #50
kmanxj5011
kmanxj5011's Avatar
rollin yet?
Old December 14th, 2011, 08:23 PM   #51
boggin-machine
boggin-machine's Avatar
how did i miss this. its looks like it is going to be awesome when finished, rangers are the new hot thing huh. its crossed my mind to build one actually as well. they are pretty neat little trucks.
Old December 15th, 2011, 09:01 PM   #52
robbietap
Thanks, i'll get some updates up as soon as this futtin computer gets back up and running.
Old December 15th, 2011, 10:23 PM   #53
Christmas Cookie
rack tap re-rack click
Christmas Cookie's Avatar
I think you need to rethink those rear shock mounts
Old December 16th, 2011, 06:23 AM   #54
robbietap
Yeah, I'm prepared for them not to work as I imagined. I will take a couple trips on them before I change it up.
Old December 16th, 2011, 06:28 AM   #55
robbietap
Front shock mnts. welded in, made up some bushings for my rear sway bar, and made some clearance for the rear shocks.
Old December 16th, 2011, 06:36 AM   #56
kmanxj5011
kmanxj5011's Avatar
Looks good. What bender do you have?
Old December 16th, 2011, 03:41 PM   #57
robbietap
JD 2, i put a air over hydro cylinder on it, i'm not built for manual bending.
Old December 16th, 2011, 03:42 PM   #58
kmanxj5011
kmanxj5011's Avatar
haha
You gonna be around tonight? Im gonna be over that way.
Old December 16th, 2011, 04:01 PM   #59
Strangler
Strangler's Avatar
I
Awesome build. I would outboard those rear shocks tho. My (very) limited experience with airshocks is that they can be overpowered by leverage very easily. Being mounted that close to the center of the axle is going to make your swaybar working overtime.
Old December 16th, 2011, 05:40 PM   #60
robbietap
Might be over the daughters place, more than welcome if lights are on.
Page generated in 0.23080 seconds with 84 queries
