02 montecarlo - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 20th, 2011, 10:54 PM   #1
84ChevyMuscle
BigBoysNeedBigToys
84ChevyMuscle's Avatar
Send a message via AIM to 84ChevyMuscle
Default 02 montecarlo
i have an 02 monte carlo, when i run it for a short period of time, and go to start it afterwards it doesnt want to start. i dont know what could cause this, but when it runs, it runs fine. i figure its either the fuel pump or the ignition cylinder, but i dont know how to determine my cause. Any help would be appreciated
84ChevyMuscle is offline   Reply With Quote
Old July 21st, 2011, 04:04 AM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
I would start with ignition. if you have spark then figure out if you have fuel.
Yetti
Old July 21st, 2011, 08:03 PM   #3
RADRICK
RADRICK's Avatar
security light on?
Old July 23rd, 2011, 04:35 PM   #4
84ChevyMuscle
BigBoysNeedBigToys
question though if it is the ignition cylinder would i still have spark? i talked to a guy at work that said it turns off my injectors
Old July 24th, 2011, 05:43 AM   #5
RADRICK
RADRICK's Avatar
From what I've read it will cut injector pulse. It pretty common for ign. cylinder to go bad on these cars, but also pretty common for bcm to go bad and cause same symptons. Are you having any other odd electrical problems?
Old July 24th, 2011, 10:32 PM   #6
84ChevyMuscle
BigBoysNeedBigToys
no not really, the only thing that doesnt work correctly is the switch for the fan speed for the heater, but other than that everything works fine, now if it was the ignition cylinder, would it even turn over or would it just do nothing, my car turns over still
Old July 25th, 2011, 11:08 AM   #7
Cool parts peddler
Ironman Offroad's Avatar
Stop by and I will try to walk you thru it.
Page generated in 0.18263 seconds with 44 queries
