lug nut help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 20th, 2011, 03:34 PM   #1
2fst4you
2fst4you's Avatar
Default lug nut help
I recently put some 1/4" spacers on my jeep now the lug nuts are really tight and won't come off. I broke a wheel key off inside the star part of the lock and stripped a lug nut.
Anyone have some advice as to getting them both off?
Old July 20th, 2011, 04:33 PM   #2
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
Torch
Old July 20th, 2011, 04:35 PM   #3
in2deep
Hole tester
i would guess u didnt have enough of the stud for the nuts to thread on to and it started to pull the threads off the nut or stud a impact gun should rip them off or big cheater bar
Old July 20th, 2011, 04:46 PM   #4
NitzPixs
It Lives once again!!!!
NitzPixs's Avatar
That or they got cross threaded.....Works better than lock-tite for sure....
You may have to cut them off, not an easy task unless you dont care for your rim....But I would try a impact gun and a good impact gun first and if need be hammer a socket onto the stripped out lug nut....Good Luck...
NitzPixs is offline   Reply With Quote
Old July 20th, 2011, 04:52 PM   #5
Dylan
Dylan's Avatar
did you strip a lug nut or peal those stupid chrome covers off? If you stripped it, make sure you use the correct size socked (and NOT a 12 point). There should be no way to strip a lug nut on a jeep unless you have the wrong size socket (or shitty sockets).
If you installed 1/4" spacers then your studs were too short (unless you installed longer ones which I doubt because I didn't see a post about it), and like mentioned above, you F'ed up the threads on your studs. Plan on getting new studs as well.
Oh and my advice about the broken lock, either go buy a new "key" for it or pound on a 12 point and use a cheater bar with EVEN force and not jumping on it.
You could also torch it out and buy a new wheel.
Better yet, swap axes
Old July 20th, 2011, 10:08 PM   #6
Bishop
Bishop's Avatar
Buy these. http://community.craftsman.com/Craft...-Pouch-reviews
Hammer it on, impact it off.
Buy longer studs and new lug nuts.
Old July 20th, 2011, 10:21 PM   #7
jaysusr
jaysusr's Avatar
ive split lug nuts with air chissel. it works
Old July 20th, 2011, 10:24 PM   #8
Bishop
Bishop's Avatar
Also done this. Not pretty. Wanted to pull my hair out. It would be my last choice, but it does work.
Old July 21st, 2011, 09:18 AM   #9
TopHeavy
Yikes!
TopHeavy's Avatar
Righty Tighty, Lefty Loosey.
Buy My CJ7
TopHeavy is offline   Reply With Quote
Old July 21st, 2011, 09:27 AM   #10
twodollars
twodollars's Avatar
I have used the sockets for rounded off nuts / bolts, worked great, but destroys the fastener you are using them on. Think I picked them up at sears. I used them to take off the locking lug nuts after I lost the key.
twodollars is offline   Reply With Quote
Old July 21st, 2011, 11:10 AM   #11
2fst4you
2fst4you's Avatar
Originally Posted by Fullsize4life View Post
Torch
Anyway to do this without destroying my rim....
Old July 21st, 2011, 11:12 AM   #12
2fst4you
2fst4you's Avatar
Used an impact and it wouldn't turn them. Tried a cheater bar and the lock key broke and the chrome stripped off the regular lug nut
Old July 21st, 2011, 11:16 AM   #13
2fst4you
2fst4you's Avatar
Stripped the chrome coating off then it got ruined. Ya I need longer studs where do I get those? Ill be buying a new key but the star part got broken off in the lock so not gonna break it again. Tried pounding a 12 point on it but the lock is real hard steel.
Time for my d60 haha
Old July 21st, 2011, 11:17 AM   #14
2fst4you
2fst4you's Avatar
These work? Think I'm gonna pick up a set if that doesn't work air chissel and lastly torch ha.
Thanks guys
Old July 21st, 2011, 11:24 AM   #15
Don't use a torch.
You can buy longer studs at any decent auto parts store. Just take an old one in and show them what you need. Or............... take your wheel spacers back off. In case you don't know, you are reducing the life of your wheel bearings.
Old July 21st, 2011, 11:36 AM   #16
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
I hate those locking lug nuts. I had one strip on the last truck. I used the key to take off the other 3, then sprayed the rim with anti-spatter, welded the key to it, removed it, and threw it all in the trash.
Old July 21st, 2011, 07:13 PM   #17
littletrucker
I'd hit that
littletrucker's Avatar
Get a real impact gun, and get rid of the locking lugs, Do you have the stock jeep lug nuts? If so, the chrome cover is known for splitting off then you just have the steel lug nut left which you need a half size socket to get off, but if you already rounded it off with the 19mm get a little smaller impact socket and hammer that thing on there and impact it off. Id would try one of those lug nut remover like an inverted easy out that fit it if that doesnt work
What did you put your lug nuts on with? How many ft lbs?
Old July 21st, 2011, 07:51 PM   #18
BlackBetty97
We Like it Loud
BlackBetty97's Avatar
I got really screwed and had a big problem where the rims and lug nuts corroded together, my IR Ti2135MAX would not pop them and was just rounding out the nuts. A 3/4 inch drive gun did not work either. I ended up pulling the shafts and cutting the back side of the studs off with a torch. Suddenly, everything fell right apart as though there had never been an issue. Didn't ruin the wheels either.
BlackBetty97 is offline   Reply With Quote
Old July 21st, 2011, 07:56 PM   #19
03tjsport
Red Dragons!
03tjsport's Avatar
If the caps are off you can drill out the studs too...not fun,but won't damage the wheel.
03tjsport is offline   Reply With Quote
Old July 21st, 2011, 08:15 PM   #20
This, if you want to save your rim.
Page generated in 0.32951 seconds with 83 queries
