Should relays get warm? what causes this? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 20th, 2011, 11:33 AM   #1
Ford rules
Ford rules's Avatar
Default Should relays get warm? what causes this?
So i have a 95 ford ranger with a fuel injected 5.0 and 4R70W tranny 203/205 transfer case. My question is that there are three relays under the hood that will get some what hot when the truck is either running or just with the key on and engine off they are the WOT ac cut off relay fuel pump relay and pcm power relay. Is this normal?
Thanks
Old July 20th, 2011, 08:53 PM   #2
shawn
Resident HVAC/R Jambi
shawn's Avatar
Of course. If the coil of the relay is energized it's going to get warm.
Old July 20th, 2011, 09:06 PM   #3
jaysusr
jaysusr's Avatar
Correct. A relay is just an electric switch.
Old July 20th, 2011, 09:34 PM   #4
Ford rules
Ford rules's Avatar
So i shouldnt worry that it gets warm then?
I was thinking the same thing but my brother made a big deal of it and i didnt want it to lead to problems down the road (truck burns to ground).
Old July 21st, 2011, 12:12 AM   #5
bdd1469
bdd
bdd1469's Avatar
If your using the proper gauge wire,and they have a good ground,dont be afraid of a lil heat,they are "working" they might get hot.
Old July 21st, 2011, 07:04 AM   #6
Ford rules
Ford rules's Avatar
Well there the factory wiring and relays so they should be wired properly anyways lol
Page generated in 0.16822 seconds with 41 queries
