TPI. No injector pulsing.. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 17th, 2006, 05:41 PM   #1
clarkstoncracker
lol
clarkstoncracker's Avatar
Default TPI. No injector pulsing..
I understand that the injectors should have 12V when the key is on. They do
I know the ECM grounds out the injectors to fire them. I'm curious how to monitor the ignition pulse wire to the ECM that controls the injectors.. Is it a open/close loop for the pulse wire from distributor to ecm, or is it putting resistance on it?
Old September 17th, 2006, 07:20 PM   #2
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Here ya go Bub-Rub...
tpi-pin-voltage.pdf
Old September 17th, 2006, 07:32 PM   #3
Mongo
Mongo's Avatar
I believe it's open/close, controlled from the injector driver in the ecm. You should be able to check it with one of those little "peanut" lights(#194?) just bend out the prongs and plug them into the injector plug on the wire off of the injector. It should show if you have + and a good ground. Also, what's your fuel pressure, I think it should be like 34-47????
Mongo is offline   Reply With Quote
Old September 17th, 2006, 07:33 PM   #4
Mongo
Mongo's Avatar
tpi-pin-voltage.pdf
I type slow.
Old September 17th, 2006, 07:37 PM   #5
clarkstoncracker
lol
tpi-pin-voltage.pdf
Old September 17th, 2006, 07:48 PM   #6
Mongo
Mongo's Avatar
Originally Posted by clarkstoncracker
I try so hard to win your approvial.
Old September 17th, 2006, 08:54 PM   #7
clarkstoncracker
lol
Not after you call and wake my ass up at 7am. :miff:
Old September 17th, 2006, 09:21 PM   #8
Mongo
Mongo's Avatar
Do it run?
And it was 9:30, 1/2 the day was gone.
Old September 17th, 2006, 09:42 PM   #9
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
CC see the #5? thats the one I think your distrib is missing
Yetti
Old September 18th, 2006, 04:35 PM   #10
Tonka
Tonka's Avatar
He's running an HEI distributor, like the one on the left
Old September 18th, 2006, 04:48 PM   #11
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Well that's just dumb....:miff:
Old September 18th, 2006, 07:42 PM   #12
Yetti
Yetti's Avatar
Notice that BOTH have a 4 wire connector? the TPI needs to know what the distrib is doing in order to place its port time in sequence. without the trigger wires to the computor you are dead in the water. from what I talked to cc about last night in chat he didn't have any of the 4 wires hooked up.
Yetti
Old September 18th, 2006, 08:33 PM   #13
clarkstoncracker
lol
I ordered a new loaded distr today.. I was not getting impulses out of it for the ECM to read..
The replacement parts were 87 bucks, or a new one was 109.
Its worth 22 bucks not having to take it apart.
Hopefully she fires tomorrow.
Old September 18th, 2006, 09:06 PM   #14
Yetti
Yetti's Avatar
cool
Yetti
Old September 18th, 2006, 10:08 PM   #15
Buggy_Tim
(513) 891-8372
Buggy_Tim's Avatar
Keep us posted.
Old September 18th, 2006, 11:29 PM   #16
Mongo
Mongo's Avatar
:stan3:
Page generated in 0.35170 seconds with 71 queries
