5.0HO and 5.8 intakes - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 18th, 2011, 05:21 PM   #1
Wehan
Wehan's Avatar
Default 5.0HO and 5.8 intakes
A friend at work says he has a BBK intake (upper and lower) off of an early model ford lightning 5.8. Will that work on my 5.0 HO and what would benefit from this (high end power, low end torque, turn your engine into a turd.....)
Wehan is offline   Reply With Quote
Old July 18th, 2011, 10:05 PM   #2
sandguy356
bronco built for fun
sandguy356's Avatar
First, 5.8 intake lower will not work on 5.0, second without a cam change, I doubt you would really see all the benefits of a better intake anyway.
sandguy356 is offline   Reply With Quote
Old July 19th, 2011, 03:44 PM   #3
Wehan
Wehan's Avatar
My friend said that intake would work with gt-40p heads. Any truth to this? I plan on an aftermarket cam after I get the intake and heads upgraded to something a little nicer, I was thinking gt-40p heads and "cobra" intake off an explorer.
Sent from my iPod touch using Tapatalk
Old July 19th, 2011, 03:51 PM   #4
osteologation
Everyday I'm Shufflin'
osteologation's Avatar
The 5.8 has a taller deck height. Which means the heads are farther apart. So the lower intake is wider than a 5.0. It will not fit physically. That is why it won't work. Idk enough about bbk uppers to say what lowers it would work with, other than a bbk lower for a 5.0 I assume.
Old July 20th, 2011, 01:49 PM   #5
Wehan
Wehan's Avatar
Ok, sounds like I can keep shopping then. Thanks for the good info.
Old July 22nd, 2011, 10:12 PM   #6
Never_Evil
The explorer intake is similar to the first gen lightning intakes with the exception one is 5.0 and the other is 5.8.
The best donor vehicle for parts would be a 96 explorer. They have the regular gt40 heads and the gt40 style intake.
Old July 22nd, 2011, 10:34 PM   #7
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
The Cobra/explorer/gt40 are basically the same intake. Cobra/Explorer are just cast (cheaper) versions of the gt40.
They are entry level performance intakes. You will still pick up power by bolting one on. About 10 hp, and it is a top end gain, maybe not the best in a Jeep. The heads on a 302 are the key to power. The stock roller h.o. cam can make good power and better torque. Sleeper too.
Evo3D
Old July 30th, 2011, 12:36 AM   #8
Wehan
Wehan's Avatar
Well I had the block checked and it needs full rebuild so it's for sale or going to scrapyard.
Page generated in 0.20579 seconds with 47 queries
