collapsed lifter :( Pics page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 17th, 2011, 12:19 PM   #1
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Default collapsed lifter :( Pics page 2
This weekend at silver lake I managed to collapse a lifter in my Mopar 360. Comp cams less then few thousand miles. What can cause this? 5500 rpm all day? Lol
Old July 17th, 2011, 12:28 PM   #2
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Its hydraulic flat
Old July 17th, 2011, 03:59 PM   #3
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
sounds to me that maybe the check ball inside the lifter is stuck open. possible dirt contamination is a likely cause.
Old July 17th, 2011, 04:14 PM   #4
jaysusr
jaysusr's Avatar
Not that u want to but itll run like that for a long ass time.
Old July 17th, 2011, 04:57 PM   #5
Cool parts peddler
Ironman Offroad's Avatar
Did you use an oil that has extra zink to protect the cam?
If you changed the oil after the cam install, you have to use an additive unless you are using the correct oil for a flat tappet cam.
GF4 oils have very little zink and phosphorus.(sp)
Old July 17th, 2011, 05:00 PM   #6
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
I just started using an additive after reading about the zinc/phosphorus cam issues
Sent from my PG86100 using Tapatalk
Old July 17th, 2011, 07:36 PM   #7
pfreer
old newb
pfreer's Avatar
assuming you replaced the lifters when you did the cam?
Too many rRRRRs sounds like. I've done it in an old pontiac once, rocker arm just kinda layed there, shot fire out the quadrajet on every revolution...
pfreer is offline   Reply With Quote
Old July 18th, 2011, 04:22 PM   #8
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
This.
And cam break-in without the correct oil will do it also.
Old July 18th, 2011, 05:05 PM   #9
littletrucker
I'd hit that
littletrucker's Avatar
Do you have a messed up lifter or did you wear a lobe off the cam?
Old July 18th, 2011, 05:18 PM   #10
Jeeperz Creeperz
GL 4x4 Vendors
I'd bet both.
Old July 18th, 2011, 05:36 PM   #11
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
I did the proper break in and additives and all that.
I just think running at those RPMs finally caught up to it and collapsed it. I have not drained the oil yet to see if there is metal in there... so it is very possible its a bad lifter / cam lobe.
I did some reading and people are saying those lifters do not like prolong high RPM.... So do I limit my RPM down to 5k or do a solid lifter cam?
Old July 19th, 2011, 03:20 PM   #12
Cool parts peddler
If it was broken in properly and has the correct lubricant there is no rpm limit for the cam and lifters, only for the valve springs. Solid lifters would give you no advantage if the heads are stock castings.
Does a Hemi run solid lifters? Not the new ones and they run good #'s.
Old July 19th, 2011, 03:23 PM   #13
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Guess I never thought of that....
Seems like a lot of people with the comp cams have had lifter issues. I remember hearing they had a recall on their lifters.... ? Either way I'll pull it apart and see if the cam is gone. I'll keep ya all posted!
Old July 19th, 2011, 03:27 PM   #14
ajmorell
When I bought my stuff from Comp the guy told me it was imperative to run the ZDDP additive and/or an oil with extremely high zinc levels. FWIW I've been running Amsoil Signature Series since break in (12k miles ago) with 0 issues.
Old July 19th, 2011, 04:10 PM   #15
Cool parts peddler
The zddp additive is the only thing that will keep the cam and lifters happy until they have MANY hours on them. From what I have read, the zddp impregnates the metal making for a surface that will withstand the extremely high loads the cam nose sees during operation.
Most cam manufacturer's also offer Nitriding (an additional hardening process) of cams at an additional charge to insure better break in results. Cam and lifter break in is a longer process than most people understand.
Old July 19th, 2011, 04:45 PM   #16
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
comp cams lifters have been known to have issues. my neighbors 427 BBC had brand new CC lifters in them and he just had 4 of them come totally apart in the motor. the cheap circlip that holds the body together broke. the engine only had maybe 5 hours of run time at best.
Old July 19th, 2011, 04:59 PM   #17
joe_jeep
welfare wheeler
joe_jeep's Avatar
wrong valve springs/coil bind possbily?? random idea.
Old July 19th, 2011, 10:04 PM   #18
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Ok so I pulled it apart today. I found that the lifter has a hole in the bottom and is no longer flat. It is concaved and matches the contour of the cam lobe.
The valve springs are what comp cams recommended.
Old July 19th, 2011, 10:21 PM   #19
kevinr839
kevinr839's Avatar
It seems to me that car craft had a write up in the last month or so about cam and lifter break in procedures and oil comparisions. Maybe worth reading up on. Oil has changed alot for the worse in the last few years. I'll check the "library" and see what month it was in
kevinr839 is offline   Reply With Quote
Old July 19th, 2011, 10:25 PM   #20
kevinr839
kevinr839's Avatar
I checked, it was in the august 2011 car craft, pretty good article.
Page generated in 0.35532 seconds with 83 queries
