Never Enough.....SAS blaZeR2 - Page 7 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old November 23rd, 2011, 04:02 PM   #121
Freak
Wheelin the HD
Freak's Avatar
I could still bring my computer by on saturday, work will have me in Mt Pleasant at some point.
I thought you tried a different computer already?
Old November 23rd, 2011, 04:18 PM   #122
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
I did but it wasn’t programmed for my vin. The Autozone one is, I’m not sure if a computer will work without it being flashed for the right vin. Thanks for the offer tho
Old November 23rd, 2011, 07:09 PM   #123
Freak
Wheelin the HD
Freak's Avatar
They dont have to be "flashed for your vin" you have to do a "crank relearn" though aka "flash the computer". They have do it yourself instructions, but i hear its finicky and hard to do, the one from autozone is probably set to relearn when you start it up.
This could definitlly expkain your spark issue.
Old November 23rd, 2011, 07:13 PM   #124
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
I hope so. Do you have any links on the crank relearn process, in case the Autozone one doesn’t work? I’ve google’ed and everything I’ve fond says take it to the dealer.
Old November 23rd, 2011, 07:19 PM   #125
Freak
Wheelin the HD
Freak's Avatar
You look on zr2usa.com? That is where I hvae read about it.
Old November 23rd, 2011, 07:26 PM   #126
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Yeah Im a member over there two, but their search sucks. It works as long as you have an hour or two Ill start looking around over there after I eat some turkey.
Old November 23rd, 2011, 07:29 PM   #127
Freak
Wheelin the HD
Freak's Avatar
http://www.fullsizechevy.com/forum/g...t-relearn.html
Old November 23rd, 2011, 07:34 PM   #128
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Thank you sir
Old November 23rd, 2011, 07:43 PM   #129
Freak
Wheelin the HD
Freak's Avatar
Thank me if it works, looks like it could be a waste of an hour looks like there is a reason they say take it to the stealer.
Old December 2nd, 2011, 01:43 AM   #130
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Ok its its almost 3, I'm covered in snow, and the shop light went out at 2. BUT I think I have this rig figured out
All tests led to 2 bad coils. Maybe something else is wrong and its killing the coil, I don't know. However it has 12v and a pulse from the ICM and still no spark. I used this link to come to this conclusion.
http://easyautodiagnostics.com/gm_mi...re_tests_5.php
Thanks for the link Dad!!!
Old December 2nd, 2011, 01:44 AM   #131
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Ill report back in the am after the part store opens. Time for sleep I'm tired lol
Old December 3rd, 2011, 09:58 PM   #132
BeaverTown
Cuck Fancer
BeaverTown's Avatar
Send a message via Yahoo to BeaverTown
well...
BeaverTown is offline   Reply With Quote
Old December 4th, 2011, 02:22 AM   #133
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
No Luck New coil and nothing. I've tried resting the security system tonight and that didn't work either.
Old December 5th, 2011, 12:11 AM   #134
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Well not having a running truck has some advantages NO GAS lol The saved money has bought my books for next semester and these
Old December 5th, 2011, 01:00 AM   #135
Freak
Wheelin the HD
Freak's Avatar
Fancy... did you go to spicer Balljoints? What are you running for Ujoints?
Old December 8th, 2011, 06:20 PM   #136
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Still autozone specials on one side and factory on the other and I went with Alloy U joints. They were cheaper than Spicer's (plus full circle clips)!!!
Old December 9th, 2011, 05:37 PM   #137
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Hmmm for some reason there is a disassembled cherry picker in my apartment
Ok so I gave on trying to track down why my truck won't start. I've just been throwing parts and $$$ at it, so it was time to swap in a running motor, harness, and computer. Freak is dropping the motor off on sunday, so until then I'll be striping and getting the old motor ready to pull. For the new motor I have picked up a new oil pan gasket, rear main seal, timing set and gasket kit, exhaust manifold gaskets, and valve cover gaskets. Is there anything else that you would replace on a used motor short of a full rebuild?
Old December 9th, 2011, 06:08 PM   #138
TanTahoe
TanTahoe's Avatar
Id replace the intake gaskets while your at it. Those 4.3 seem to have issues with them.
TanTahoe is offline   Reply With Quote
Old December 9th, 2011, 07:03 PM   #139
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Ok thanks Ill ask freak if they ever been replaced.
Old December 9th, 2011, 07:08 PM   #140
hondadirtracer
Skymaster
hondadirtracer's Avatar
All of the new parts you just put on your old motor.
hondadirtracer is offline   Reply With Quote
Page generated in 0.37554 seconds with 84 queries
