Never Enough.....SAS blaZeR2 - Page 5 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 17th, 2011, 01:18 PM   #81
Freak
Wheelin the HD
Freak's Avatar
Told you linux > windows
Old October 22nd, 2011, 07:12 PM   #82
wadey
┌∩┐(Ú_ů)┌∩┐
wadey's Avatar
Well the the blazer finally made it home....
Thanks Dad for the ride
Old October 22nd, 2011, 08:02 PM   #83
BeaverTown
Cuck Fancer
BeaverTown's Avatar
Send a message via Yahoo to BeaverTown
So I take it your back in White Lake? If you need a hand up here, let me know.
BeaverTown is offline   Reply With Quote
Old October 22nd, 2011, 08:28 PM   #84
wadey
┌∩┐(Ú_ů)┌∩┐
wadey's Avatar
Itís in Mt. Pleasant now.
Thanks, I might take you up on that offer once I get my shop manuals shipped up from home. But until then I canít really do anything, everything obvious has been replaced and checked. Iím lost.
Old October 22nd, 2011, 08:46 PM   #85
Wheelman
Extreme Mudder
Wheelman's Avatar
Great build i live in Pontiac and drive to big rapids 2-3 times a month. If you ever need anything transported up there.
Wheelman is offline   Reply With Quote
Old October 22nd, 2011, 08:51 PM   #86
buttercr125
I work out
buttercr125's Avatar
I'm still available to lend you a hand.
Old October 22nd, 2011, 08:58 PM   #87
BlzrNick
Built not bought
BlzrNick's Avatar
I take it the pcm wasnt the issue?
BlzrNick is offline   Reply With Quote
Old October 22nd, 2011, 10:10 PM   #88
Sandy_gIna
Lets do this
Sandy_gIna's Avatar
I hope you get everything figured out. Thanks for the present. I will come up hopfully befor the snow flies. And it better be running again. Or you can buy the focus next year.
Sandy_gIna is offline   Reply With Quote
Old October 23rd, 2011, 12:08 AM   #89
14x4
14x4's Avatar
Your Blazer looks awesome, Wadey. I have to ask though (and I apologize if this has already been covered), why keep the front cross member? I can't believe that doesn't hit the diff cover or tie rod.
I do really like the look of the skid plate with a SFA.
14x4 is offline   Reply With Quote
Old October 23rd, 2011, 11:07 AM   #90
wadey
┌∩┐(Ú_ů)┌∩┐
wadey's Avatar
Thanks, and if I ever need anything brought up ill let you know
Yeah like I told bevertown I wont be doing a whole lot until I get my books. But if I get stuck after I that Ill be sure to give you a call. Thanks again for all your help already!
Nope, at least we dont think so, it could be anything at this point.
Thanks man for the all the help and comfy couch Let me know you your ready to start working on the blazer, even if it is just to replace the back window
As much as I liked your gas saving, nice riding, street legal gocart. I have to have a truck and trailer as my next ride. Last two times out I broke it. Time for my dd to turn into a rig
Old October 23rd, 2011, 11:25 AM   #91
wadey
┌∩┐(Ú_ů)┌∩┐
wadey's Avatar
Thanks, I kept it for a couple of reasons. Main reason was to keep it simple, why reinvent the wheel if you donít have too? Most of the cross member is there, it has been trimmed on the back side for the tie rod to clear. But keeping it kept me from having to build another cross member, as that is the only one in the front part of the frame. As you noticed it let me keep the skid plate which I really like, tie rod protection is sooo nice, and being able to keep the oil filter in the stock location made everything that much easier.
Best part of keeping the skid, is at first glance it looks like its IFS. In fact the only part that gives it away from the front is the flat tie rod, even then itís fooled quite a few.
Nothing like a sleeper
Old November 1st, 2011, 07:00 PM   #92
wadey
┌∩┐(Ú_ů)┌∩┐
wadey's Avatar
Whatís everyoneís opinion about the almost alloy kit? I canít afford chromos but I can build my own almost alloy kit in my shop class. Is this better than just tacking the caps? Or does the heat from the welding weaken the shaft?
http://www.ironrockoffroad.com/Merch..._Code=IR-S_AAK
Old November 2nd, 2011, 09:02 PM   #93
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Not sure you would have much fun installing those shafts. I had trouble fitting mine thru the knuckle with just tack welds to hold the caps.
Honestly, I see no real benefit to doing that anyway, not sure I would even bother. Just tack the caps.
Old November 2nd, 2011, 09:14 PM   #94
wadey
┌∩┐(Ú_ů)┌∩┐
wadey's Avatar
hmm thatís a good point, I forgot about space limitations on the knuckle.
I had my caps tacked and I broke one side at the ears, probably from the ball joint failing. But the other side stretched far enough to oval out the yokes and pop out a cap. They are bad enough that I can see day light around all of my caps and their only held in by the tacks. I was hoping that these would be a cheap way to keep the ears from stretching.
Old November 2nd, 2011, 09:34 PM   #95
BeaverTown
Cuck Fancer
BeaverTown's Avatar
Does it run yet?
Old November 2nd, 2011, 09:36 PM   #96
wadey
┌∩┐(Ú_ů)┌∩┐
wadey's Avatar
Nope not yet
Old November 2nd, 2011, 10:09 PM   #97
BeaverTown
Cuck Fancer
BeaverTown's Avatar
When are you getting the tech manuals? What have you changed so far? I know you said it wasn't getting fuel. I'm assuming you did pump and filter, did you check fuel pressure at the rail?
Old November 2nd, 2011, 10:27 PM   #98
wadey
┌∩┐(Ú_ů)┌∩┐
wadey's Avatar
I should have the manuals by the weekend, and I found out it wasnít a fuel problem. Itís a problem with the spark. I have replaced the entire ignition system with no luck. I found that I have power to the coil, leaving it to be the interment pulse. The crank position sensor sends the pulse to the computer and then the computer sends it to the ignitron control module which feeds the coil.
Iíve replaced and checked for continuity at the CPS so the computer is getting a signal. However it looks like this is also how the computer shuts the truck off. So it could be a security problem or the Inertia switch.
Could be anything at this point
Old November 2nd, 2011, 10:46 PM   #99
deerebowtie
Unchained
deerebowtie's Avatar
there's a lot of help on the board here, throw ta synopsis and lets toss some ideas.
Old November 3rd, 2011, 05:02 AM   #100
Tacking the caps won't keep the ears from stretching. They just keep the caps from coming out if the snap ring fails. I've seen a lot of people do it but I've never seen the need if the yoke is in good shape. If it's not in good shape, you're going to have joint failure anyway.
Page generated in 0.51922 seconds with 84 queries
