Never Enough.....SAS blaZeR2 - Page 4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 27th, 2011, 07:40 AM   #61
BIGDANE36
BUY MY TRUCK
BIGDANE36's Avatar
My buddy mike actually sold you your front drive shaft so if your ever in the area stop by and I actually talked to you once when you workted at the car wash I was in the black jimmy
BIGDANE36 is offline   Reply With Quote
Old October 2nd, 2011, 12:09 AM   #62
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
^^ I would stop by, but im up in mt. pleasant right now. Tell mike that that front drive shaft is holding up even tho he didn't think it would
Old October 2nd, 2011, 12:31 AM   #63
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Default NP 233/231 help
Ok I broke a front axle shaft at R&V the other weekend and just ratchet strapped the shaft in order to keep fluid in the diff. No big deal except the front shaft spun enough to break the ratchet strap. I first thought this was due to a bad lock out on the other side, but I pulled the lock out and I am still breaking ratchet straps. Then I remembered that the shafts rotates slightly as you turn so I used a bungee, to allow for stretch when the axle rotates. This also didn’t work, so I pulled the front drive shaft and everything has been fine since.
So what did I do to my transfer case to cause it to not disengage all the time? I can spin it by hand when I’m parked leading me to think that it is in 2hi. But this obviously this isn’t the case, as there is enough force to break the straps/ bungees.
The 233 is very similar to the 231 except it is electronically shifted. So much so that I used a 231 front output, yoke, and seal on my case. So hopefully you jeep guys can help me out.
Any Ideas?
Old October 2nd, 2011, 11:05 PM   #64
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Anyone know what i did to my Tcase?
Old October 3rd, 2011, 01:57 AM   #65
BIGDANE36
BUY MY TRUCK
BIGDANE36's Avatar
Is your tcase still push button? If so a lot of the time on the 233 it will be between 2hi and 4hi do to lack of vacuum there is a cable under your battery tray you can pull back and will fully put it in 2hi if I remember correctly
Old October 3rd, 2011, 08:08 AM   #66
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
The vacuum actuator is controlled by a transfer case mounted switch, this is used to engage the CAD. The transfer case does not use vacuum for shifting ranges, the vacuum is only used to run the CAD. So with me having a solid axle, the vacuum has nothing to do with the transfer case engaging randomly.
Old October 3rd, 2011, 11:25 AM   #67
motox168
Bare Bones Offroad
motox168's Avatar
Just put a Dana 300 in then you'll be problem free lol, just seen your mini Sig thing "ride legit" and I laughed
motox168 is offline   Reply With Quote
Old October 3rd, 2011, 11:32 AM   #68
bbaXJ
Yooper In Training
bbaXJ's Avatar
It's probably just the viscosity of the fluid in the transfer case causing the front output to still turn slightly. I've heard of this being the case and I would assume that coupled with the additional gear reduction of your axle gearing it's just enough to break it. That's just a guess though....
Old October 3rd, 2011, 08:27 PM   #69
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
one hell of a t-bell run
hmm it could be that, combined with some drag from the bearings. To cause the strap to break, it was only a harbor freight strap so Im sure it didnt take much.
Old October 4th, 2011, 10:09 AM   #70
BLZR
Well there's the problem! Whenever I buy something from there I always ask myself why I just did it. It ends up in the scrap bin/trash before I know it
BLZR is offline   Reply With Quote
Old October 4th, 2011, 10:53 AM   #71
Freak
Wheelin the HD
Freak's Avatar
Warn nylon fittings on the shift fork, allowing the ring to partally engauge?
How quickly is this happening? Those Ford lockouts are famous for sticking. Could it be a Sharp edge "sawing" at the strap? Spool limited or open? I could look but my internet is slow. You need any 231/233 parts I have em.
Edit: fluid viscosity or lose engaugement ring I see you have a spool. BTW I have 2 shrot side and one long side f150 shaft for you can't find any good stubs.
Old October 4th, 2011, 01:28 PM   #72
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Yeah true, I don't know why I bought them there, just to save a buck I guess. But I always end up replacing/upgrading their junk and spend more money in the long run.
Old October 4th, 2011, 01:33 PM   #73
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
If it is the engagement ring would it act like its in 2 while sitting still? I dont remember from when I had the case apart, but Im sure its worn with all the miles on it.
Sending you a pm about the shafts
Old October 4th, 2011, 03:01 PM   #74
Freak
Wheelin the HD
Freak's Avatar
I would think that you would hear it clunk or grind if you were driving when the hubs are unlocked, do you hear a loud snap when the straps break or just notice them dangleing?
Old October 5th, 2011, 12:10 AM   #75
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Just notice them dangling, or when the shaft comes out and locks up the steering... thats a fun one
Old October 5th, 2011, 12:13 AM   #76
Freak
Wheelin the HD
Freak's Avatar
This makes me think its just rubbing through the strap.
Old October 10th, 2011, 09:13 AM   #77
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Got some new stickers
Old October 10th, 2011, 10:21 AM   #78
Freak
Wheelin the HD
Freak's Avatar
that sticker turns your tires to sticks, now your really going to break shit!
Old October 12th, 2011, 05:13 PM   #79
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
haha I know, take a look at this picture... I put the sticker on that morning
Old October 16th, 2011, 10:09 PM   #80
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Ok I know I have this already posted in 2 other places, but Im stuck in Holland and have to get back to Mt. Pleasat for class.
I am looking for a computer for my 99 s10 5speed blazer. I am looking for anything that will work and is forsale around the holland area. I also have to be able to pick it up tomorrow.
If you have anything please let me know,
Thanks
Justin
Page generated in 0.35891 seconds with 84 queries
