Never Enough.....SAS blaZeR2 - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 18th, 2011, 07:21 AM   #21
curbdog17
Mini Van
curbdog17's Avatar
Your Gramps sounds like a cool dude.
Nice build too.
Old July 19th, 2011, 11:15 AM   #22
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
thanks
I also received my wheel adapters in the mail yesterday (5x4.75 to 5x5.5). I got 4 of them so I could break one and be able to keep wheeling, break the spare and still be able to drive it home.
Old July 19th, 2011, 11:39 AM   #23
tweak
Are we there yet?
tweak's Avatar
Looks like a fun build.
Its great to have a mentor such as your Grandpa. Looks like he has some nice tools in his shop as well!
Old July 19th, 2011, 08:51 PM   #24
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Yeah it has been fun so far but we'll see how that goes once the actually swap happens.
As of now all of the hw has been done (longest part), parts bought, and the front axle is now complete hub to hub!!!
Yeah his knowledge amazes me every time we work on something... Im learning a lot from him
Old July 19th, 2011, 09:00 PM   #25
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Here is my modified rear tire carrier, I have changed the bolt pattern and moved the mount in to compensate for the new back spacing. Better departure angle and less leverage on the carrier it’s self. The mounting plate has moved down for a better view too.
Before
After
I had to relocate the plate to the middle to see it. It is two pieces of tube sleeved over top of each other with a bolt holding it together, to allow tire removal. The plate backing is made from 3/16 so if I need it I have a piece of 1' by 6" plate for a trail repair.
Any one know of a light that I could use for the rear plate? Autozone has one but the cord exits from the top, im looking for one to go trough the back.
Old July 20th, 2011, 11:59 AM   #26
BLZR
BLZR's Avatar
Looks like those axles need to get under that Blazer!
Bumper looks good btw!
BLZR is offline   Reply With Quote
Old July 20th, 2011, 12:30 PM   #27
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
Mount the plate somewhere else, the rims looks waaaay better than a tag. Almost a sin to cover it up.
Old July 20th, 2011, 04:24 PM   #28
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Thanks and the axles will go under it as soon as my grandpa has time to help, he is busy with some big races the next 2 weeks
Yeah I would have to agree with you. But that one is there just for show because I only have 4 bead locks.
The real spare is just a regular steel wheel, so the plate will help to hide the rim.
Old July 21st, 2011, 08:52 PM   #29
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Ok I have a few questions about setting up gears. How do you measure for the shims on both the pinion and the side bearings? I have seen it on Extreme4x4 but haven’t found out how to do it myself.
Also are there any tricks or tips on how to set up gears in an axle that is still in the car?
What is the proper gear oil to break in a set of gears? Regular oil for break in then full synthetic like a motor, or just run full synthetic from the start?
Any links or advice would be greatly appreciated as I’m setting up the rear end tomorrow.
Thanks
Old August 5th, 2011, 10:47 AM   #30
2fst4you
2fst4you's Avatar
Where's the updates I know the axles are under this thing!
Old August 5th, 2011, 11:05 AM   #31
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
hey you let the cat out the bag lol
I just need time to up load the pics
Old August 5th, 2011, 05:25 PM   #32
2fst4you
2fst4you's Avatar
Haha my bad. Ok cool did u get the driveshaft situation figured out?
Old August 12th, 2011, 04:21 PM   #33
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Ok it’s been awhile since I’ve posted but that’s a good thing
The blazer is finished and has been so for a about a week, I have been busy making adjustments and tweaks. Even though it is done I will still put the pictures up in order.
Here is the beginning to my 7 day build
There were a lot more parts involved with the IFS than I ever had imagined,
This about a quarter of it.
Nice and clean
First time with the tires in the wheel wells. Ended up stretching it 3 to 4 inches to clear the firewall.
This was the end of the fist day
Old August 12th, 2011, 04:29 PM   #34
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Second day
Mocked up the tie rod to clearance the front cross member
Axle tucks up nicely
Links also tuck up
Up next was the steering and track bar
Thank was it for day 2
Old August 12th, 2011, 04:38 PM   #35
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Day 3
Finished up the draglink, bending 1.5" .250 wall is not fun or easy
Did a little grinding for frame plating
Also did some parts runs, and one trip to Unlimited for an extra hiem.
Old August 12th, 2011, 04:48 PM   #36
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Day 4
Frame was plated with 3/16 before welding on the Ballistic mounts
This was its first time on its own weight (jack was there for safety not fully welded)
Truck looks high because the rear is still on 31's
Spent rest of the day grinding and tying up loose ends.
Old August 12th, 2011, 04:56 PM   #37
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Day 5
Finish welded everything up front
Then it was time for paint, My grandma was happy to lend a hand with the painting.
All cleaned up
Have to get the pics from my grandparents but I did take it around the block with only the front done. Got alot looks
Old August 12th, 2011, 04:58 PM   #38
koochman450r
koochman450r's Avatar
looks good. I dont know if you got a light for your plate. They have bolts with leds on them so you replace the top or bottom two bolts with the lights and shazzam you have a license light.
you won this battle.
Old August 12th, 2011, 05:01 PM   #39
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Day 6
Tore out the rear end for a spring over and gear swap.
We were up until 4:50 am setting up the gear and the p.i.t.a. locker twice. Apparently you have to put the pins in first with a lock right
More pics up in a bit
Old August 14th, 2011, 11:18 PM   #40
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
ok so no new pics just been too busy
But, I did pick up a front drive shaft. It is from a 4 cylinder 5 speed cherokee, and its o.d. is about the size of my finger. Im wondering if anyone knows how strong that shaft is. Im not opposed to getting a regular cherokee shaft cut down but this one fits for now and the price was right and I want to wheel
Just trying to get a feel for how long it will last.
Page generated in 0.37167 seconds with 84 queries
