Never Enough.....SAS blaZeR2 - Page 17 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 22nd, 2012, 07:23 PM   #321
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
I looked at it today and in order to run a longer pitman arm I have to cut and box the frame or space the box off the frame like the xj guys do. Haven't decided which way would be best but a spacer is a lot easier as I would have to weld by sound only. Once I figure that out I have to mount one of the hydro assist rams I picked up over the summer.
Tonight I went through and nutted and bolted the entire rig. I found a lot of loose bolts even though I just tighten everything in the summer! Thankfully all of my bolts are cotter keyed. I also found a really bad upper bj on the drivers side.
Today was also the first time I've tightened my Ballistic Joints (just over a year old). Half of a turn on one and a quarter turn on the other. I think that's pretty impressive considering there's only two of them for the entire front end.
Old October 23rd, 2012, 04:25 PM   #322
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
So my pitman arm hits my frame rail and limits my steering. I’m 99% sure this will work, it works in my head but I just want to make sure before I take the time. Can you clock a pitman arm and still get the same amount of travel out of the box? I know I'll have to file splines into the flat spots and I don’t care where the steering wheel ends up, as long as I can get lock to lock steering.
Old November 25th, 2012, 01:17 PM   #323
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Haven't touched this thing in a while because I needed some motivation and the snow definitely helped. Gota get ready for Snofari! So does anyone have any good links on rebuilding and tapping a saginaw box?
Old November 25th, 2012, 01:23 PM   #324
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Also links on nylon brake lines and hydraulic parking brakes (the lock out ball valve style) would be appreciated
Old November 25th, 2012, 03:15 PM   #325
GMKLR50
Broke wheeler
GMKLR50's Avatar
I have used poky performance.com for the break stuff before
GMKLR50 is offline   Reply With Quote
Old November 28th, 2012, 12:45 PM   #326
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
^^Thanks
Here's my ideer for a rear bumper. Any critiques before I make the real thing? FYI The shackle mounts will get moved to where ever the frame tie ins end up, so those aren't set just yet.
Gotta give a huge thanks in advance to Garrett and John for the help and the garage that John is going to let me use!!
Old November 28th, 2012, 12:55 PM   #327
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Or should I do boxier ends like this?
Old November 28th, 2012, 01:07 PM   #328
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
Did you ever get your steering takin care of? Or are you still not at lock to lock
That third bumper looks pretty good with the tire carrier. With the pipe design of the carrier, I wouldn't be surprised if you had an exocage on your mind
Old November 28th, 2012, 01:09 PM   #329
GMKLR50
Broke wheeler
GMKLR50's Avatar
Well the second will take far less work to make but I like the first on better, just add the tire carrier to it.
just read what I wrote for poky performance? I meant Pollyperformance
Old November 28th, 2012, 01:12 PM   #330
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Kinda.. I have more than what I did have but not all the way, however the parts to get full steering are at home so I'll grab those at xmas.
They're all wide enough to mount a "tire carrier" too
That being said which one do you like?
Old November 28th, 2012, 01:14 PM   #331
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Thats the one I'm leaning towards too.
haha yeah I figured that
Old November 28th, 2012, 01:18 PM   #332
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
Yea I have some slop in the wheel and everything is tight so I'm guessing it's more than likely the steering box. I'm upgrading to a Durango before SnoFari so I won't have to worry to much about running 35s.
IMO I like that step bumper. Just fab a box tube carrier and call it good. Blazer will look good with a custom rear bumper!
Old November 28th, 2012, 01:22 PM   #333
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Cool, but don't spend that money just yet. You can tighten your steering box for free and you only need 2 tools.
Which bumper is that? the first or the second one? And I want a tree proof bumper so it needs to be attached at 2 separated points.
Old November 28th, 2012, 01:25 PM   #334
BeaverTown
Cuck Fancer
BeaverTown's Avatar
Send a message via Yahoo to BeaverTown
I like one and two. All the stuff that's on 3 could be added to 1 or 2 pretty easily anyway so build what you like.
I didn't know that you were jewish. Will the Star of David make the cut?
BeaverTown is offline   Reply With Quote
Old November 28th, 2012, 01:28 PM   #335
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
Beat me too it!
Looks like the first and second pic are the same bumper, just you have the bumper in the second pic in like a EDIT mode on Solidworks or something. That bumper with a tire carrier would be golden, or in your case Kosher
Old November 28th, 2012, 01:30 PM   #336
8PTBUCK
I'm the dude, man
8PTBUCK's Avatar
Okay just let me know. I'm going to replace it eventually because it's leaks all over my dads new driveway and he doesn't like it too much
Well, he used to hate it. But now I think he's learned to accept it. Whenever he looks at a stain on the blacktop, he chuckles
Old November 28th, 2012, 01:30 PM   #337
2fst4you
2fst4you's Avatar
I like the first one just add a tire carrier and it will look sick! How you going to make the rounded corners?
Old November 28th, 2012, 01:32 PM   #338
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Actually 1 and 2 are the same just different views. That shitty tire carrier was just a random idea, but I plan on building something that mounts off an exo in the future.
I picked up a .35 spool of wire for you. Do you have the tips for that size? If not I can grab some for ya
Old November 28th, 2012, 01:35 PM   #339
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Same way as I did the front. Cut the curve into the top plate, then slice up the side plate at 1" intervolves and bend it to fit the curve of the top piece.
Old November 28th, 2012, 01:37 PM   #340
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Beat me too it!
The two of you!
Its Catia v5
Page generated in 0.42148 seconds with 84 queries
