Never Enough.....SAS blaZeR2 - Page 14 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 13th, 2012, 06:39 AM   #261
242XJ
242XJ's Avatar
looks good wade, did that drive shaft fit?
242XJ is offline   Reply With Quote
Old April 13th, 2012, 08:52 AM   #262
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Thanks guys!
Kevin- I haven't even looked at that ds. I'm just going to put in my sye and run a new one instead. And defiantly a good call on the spring shop!
Old April 15th, 2012, 03:19 PM   #263
242XJ
242XJ's Avatar
Good deal on the springs. I will get my next set from them!
Old April 19th, 2012, 06:43 PM   #264
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Which winch?
I have a chance to pick up either a smittybuilt xrc8 for $150 with one pull ever on it. Or a Warn 12k with a in cab remote and 125ft of cable on it for $300. Either one will be getting a new rope and fair lead, along with a good cleaning and grease change.
With the Smitty the cable and fair lead are in good enough shape to sell so I would be looking at 100 total.
The Warn is older than the smitty but nothing a coat of paint cant fix. It is slower than the smitty but it draws a lot less power. It is also weighs 42lbs more. The main problem is that it is too wide and I would have to cut down the drum. Which I'm willing to do if it would be worth it.
Which one would you pick up?
Old April 19th, 2012, 06:51 PM   #265
jeepjumper
Does not own a jeep...
jeepjumper's Avatar
Id go with yhe smitty....but im a cheap ass
jeepjumper is offline   Reply With Quote
Old April 19th, 2012, 06:59 PM   #266
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
What warn model?
Old April 19th, 2012, 07:04 PM   #267
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Originally Posted by Kyle M. View Post
What warn model?
MX12085 D1
I haven't been able to find out much about it online
Old April 19th, 2012, 07:41 PM   #268
BeaverTown
Cuck Fancer
BeaverTown's Avatar
Send a message via Yahoo to BeaverTown
After how well the smitty's worked on the front of the ZJ I don't think I'd spend the money on a Warn. I'm also a cheapass too.
Sent from my C771 using Tapatalk 2
BeaverTown is offline   Reply With Quote
Old April 20th, 2012, 05:43 PM   #269
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Well it looks like the smitty is going to win. It turns out I can grab a deal from the guy with the smitty who happens to have a zr2 winch specific mount, so its a no brainer. I'm picking the winch up monday, but I couldn't pass up this deal today so I got a new rope from Chetney.
However this rope came with no terminal end. Would a copper terminal crimped on the end work? Like this.
Old April 20th, 2012, 08:54 PM   #270
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
This way seems easy enough and makes sense concerning the part about damaging the rope. Any thoughts?
Attaching your new synthetic line
With Synthetic lines I do not like the side drum attachment. If you are in a side pull you could pull your line across this point and damage your line. From me you will get a taped drum end and 5" in from the end will also be taped using red electrical tape. Lay the end across your drum with the second tape mark meeting the side of the drum, and tape both points in place. The tape is just to hold it in place so you can start spooling. Then start spooling your line on over what you laid across the drum. I Highly recommend this be done under tension. Best accomplished using a helper sitting in the drivers seat with steady pressure on the brake pedal. If you do not have a helper, set the E brake with a little tension. The 5" between the two taped marks represents the minimum number of wraps you should keep on the drum at all times. When you are pulling line off, no need to count wraps, just look for the red tape on the end. When you see this, stop, you are at the minimum number of wraps needed on the drum.
http://www.krissplicing.com/vehicle-...inch-lines.php
Old April 25th, 2012, 09:10 PM   #271
2fst4you
2fst4you's Avatar
Damn leafs look nice!! Ull bend them at TT haha
Old April 30th, 2012, 11:50 PM   #272
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
So I got my winch and rope. SmittyBuilt Xrc8 and an Erin's Rope.
Looks like I'll have to shorten the rope. Smittty gives you 94', I have 100'.
That"s a broken stud for one of the power wires. Not too happy about that...
Here's the winch mount I picked up. First and last time I every buy a bolt on part. Way to much modifying to get it the way I want and I paid a stupid amount for it because I though i could just bolt it on and go. Ill make it work but right now its a huge rock anchor, After the blessing I'll sell the mount and build what I want.
So here's my new snatch block! Its one box in side another. The post office broke it out of the box twice. Then decided to tape it up and ship me an empty box! I'm thrilled
A couple of set backs but nothing too major, more like a couple of pita's all at once
Old April 30th, 2012, 11:52 PM   #273
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Thanks cam but they won't, wait to you see them in person their beef
Old May 2nd, 2012, 08:57 AM   #274
2fst4you
2fst4you's Avatar
Haha ok good. Hows she coming?
Old May 2nd, 2012, 09:48 PM   #275
VAhasnoWAVES
Dirty South
VAhasnoWAVES's Avatar
ill be by with the drill tomorrow.
VAhasnoWAVES is offline   Reply With Quote
Old May 22nd, 2012, 07:49 PM   #276
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Thanks again for bringing that by
I would of used my own but, I striped the gears out of it drilling out the fairlead holes. Setbacks aside I still got it done for the blessing and didn't even use it
The winch plate hangs below my bumper because its meant for a stock bumper so I had to get creative. So I used the skid plate that Joe gave me. He said it was too nice to cut up...
Old May 22nd, 2012, 07:50 PM   #277
RDK_YJ88
Never Lift
RDK_YJ88's Avatar
The skid looks good on there
Old May 22nd, 2012, 08:15 PM   #278
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
The weekend of the Blessing and TT cost me a power steering pump. Probably heat related, so I picked up some goodies to keep that from happening again.
Derale 14" 2-Pass Heat Sink, Auto Meter Ultra-Lite II
I couldn't wait to try it out so I grabbed a 9 volt and hit the lights!!
Hopefully the rest of the parts show up tomorrow. Placed both orders within 5 minutes of each other yesterday and my Summit order showed up today, still waiting on Jegs.
Old May 22nd, 2012, 08:19 PM   #279
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Thanks! I figured some type of use was better than no use lol. Hows that tracker coming?
Old May 22nd, 2012, 08:26 PM   #280
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I need to get a heat sink like that. What's the gauge for, power steering fluid?
Page generated in 0.38562 seconds with 84 queries
