Never Enough.....SAS blaZeR2 - Page 13 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 20th, 2012, 03:43 PM   #241
Mr. Beefy
BFT!
Mr. Beefy's Avatar
It's a 44... The words D44 and I gave it everything the truck had just = parts breakage....
Old January 20th, 2012, 08:55 PM   #242
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Originally Posted by BeaverTown View Post
I've still got stock shafts if you need them for snofari. They'd need new joints though. I'm still looking for the superwinch lockouts too. But I've got the spicers for sure.
Sent from my C771 using Tapatalk
Yeah I could use a stub if you had one and Id rather run Spicers than the Superwinches so no need to find those. You still up for the trailer fitment on monday?
Originally Posted by GMKLR50 View Post
there not phased, but its still a pain, I havent had as much trouble as you but i dont drive mine that often, Its only a trail rig and its not to bad as long as im moving and on soft ground
I found my problem, it was the steering stabilizer had slid on the tie rod and it was keeping me from turning left. Now that its fixed I can say phasing the joints is the way to go!
Originally Posted by 98-S10-lifted View Post
Sweet build! Can't easily tell from the pics, but did you leave the axles full width? How far do they stick out from the flares? Thinking about putting my BlaZeR2 through the swap.
Thanks, and yep its full width. The tires stick out about 2 inches on each side, perfect for keeping the trees away from the body. If you run the stock rear axle and use 1 1/4" (or 1 1/2" cant remember) adapters/spacers the width matches perfectly front and rear.
Old January 20th, 2012, 08:58 PM   #243
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Originally Posted by kmanxj5011 View Post
You needs 60's
Yup.
Should of done it when I built the truck but now its too late, I have too much wrapped up in the front to switch now. A 60 will happen at some point but not until after school and I have my own garage.
Old January 20th, 2012, 09:00 PM   #244
BeaverTown
Cuck Fancer
BeaverTown's Avatar
Send a message via Yahoo to BeaverTown
Yep all set for Monday. I got new (to me) tires on the trailer today. If you want the shafts and lockouts sooner I've got them all together and can get them to you this weekend.
BeaverTown is offline   Reply With Quote
Old January 20th, 2012, 09:18 PM   #245
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Sweet! I'll have to wait on the shafts till Monday, I'm working 12hr shifts on sat and sun. Any chance we could slip the blazer in the garage? I have to do a rear u joint and drill and easy out my t case fill plug.
Old January 20th, 2012, 09:27 PM   #246
BeaverTown
Cuck Fancer
BeaverTown's Avatar
We can get it in. We might have to move some stuff out but we'll get it in
Old January 20th, 2012, 09:46 PM   #247
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
haha thanks man, see ya monday
Old January 23rd, 2012, 11:38 PM   #248
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
I have to give a BIG thanks to BeaverTown!! Thanks for all the help and letting be borrow the car.
John and I were working on replacing the rear U joint, which had been welded in place because of damaged ears. That was supposed to be the last u joint for that drive shaft, but Autozone sold me the wrong one :pissed: After we ground out the old joint the drive shaft wouldn't hold the clip, so it has to be welded in place. Tomorrow Ill be driving back down to his place with my welder to finish the truck up. Then its on to the rest of the to-do list before Snofari.
Old January 27th, 2012, 06:53 PM   #249
Freak
Wheelin the HD
Freak's Avatar
you ever figure out if the truck driveshaft will be too long?
Old January 30th, 2012, 06:49 PM   #250
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Yeah its way to long like by 20". Ill have to make a parts run soon, to grab those springs and some tcase parts from Robb.
I have lots of updates and carnage pics from Snofari once everything gets back to normal around here.
Old February 8th, 2012, 08:57 PM   #251
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Ok after and before SnoFari everything was crazy and its just now starting to get back to normal. Here is everything I did before SnoFari
Went from this
To this!!! I used this thread and it can be applied to any vehicle. Works a hell of a lot better than electrical tape.
http://www.zr2usa.com/mboard/index.php?showtopic=40878
Also had some time for my rock lights
Day Light
Old February 8th, 2012, 09:05 PM   #252
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Here's the SnoFari pics
This one cost me my pass side mirror
Wheeling with my Dad!!
Old February 8th, 2012, 09:13 PM   #253
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Me and 2fst4you
Cam's lucky ass and his new Power Tank, and umm.... my award
Old March 13th, 2012, 01:30 PM   #254
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Ok its been awhile since Ive posted in here which I guess is a good thing. However some people know that my push button Tcase has been giving me some trouble. I lost 4 low at Snofari, got stuck in 4low at the mounds, and now I cant even get the truck into gear...
So with todays extremely nice weather I finally have enough motivation to swap and rebuild cases. The plan for today is to swap in my 231hd that I picked up for 75 bucks. Hopefully I can have the truck back together some time tonight or tomorrow so I can actually enjoy some of this nice weather!
I have give a big thanks to Snocross2xtremes for the ride back to his place from the Chili run, and all the help to get the truck back into 4hi which was good enough to get me home.
Pics to follow....
Old March 15th, 2012, 07:18 AM   #255
Sandy_gIna
Lets do this
Sandy_gIna's Avatar
ok its been 2 days is it in yet
Sandy_gIna is offline   Reply With Quote
Old March 16th, 2012, 09:03 AM   #256
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
No its in yet I found out that I broke the snap ring that holds the main shaft in place for the second time. So I think its time for a sye. The problem with that is that requires a new drive shaft (which I needed). But I wont put a new drive shaft on with my S shaped springs so I don't kill it. So that's new springs too. Long story short is that I know where my tax money is going, but I'll have a more reliable rig from it so its not the end of the world. Its also going to make attending the blessing a bit of a time crunch.
Old April 11th, 2012, 01:11 PM   #257
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Well I needed some motivation to work on this thing so I cleaned her up yesterday and snapped this pic. Tonight the plan is to start swapping out my old leafs for my new custom ones from A B Spring.
Also the first pic next to my dad's new rig!
Old April 12th, 2012, 10:30 AM   #258
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Last nights progress.
This is how bolts are supposed to come out right?
This was a little scary to find...
What the leafs are supposed to look like
What they looked like
Old April 12th, 2012, 09:13 PM   #259
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Got the new springs on and while they seemed stiff in the bounce on the bumper test, they actually rode really smooth. Possibly the nicest lifted truck I've ever rode in!
And my drive line vibes are now gone to the pinion angle be back to where it should be.
Military wrap on both ends
The bottom half leaf is actually a "traction aid", basically a stiffer leaf to prevent axle wrap. Which was the death of the stockers.
Head down ass up stance right now. Hopefully it will settle out, if not I'll adjust the front up to match.
Old April 12th, 2012, 09:30 PM   #260
Bruster
looking good man
Page generated in 0.50234 seconds with 84 queries
