Never Enough.....SAS blaZeR2 - Page 12 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 15th, 2012, 09:42 PM   #221
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Originally Posted by Freak View Post
Warn are extreamly similar to superwinch. I run stock spicers on mine and never broke one.
Good to know about the Warns
Originally Posted by BLZR View Post
And I've broke my Spicers fairly easilly running 37's. Slugs are nice but it sucks not being able to unlock them
If I ever ran slugs it would be just to get off the trail. Not having hydro assist and a spool sucks.
Old January 15th, 2012, 09:50 PM   #222
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
This chart has some wrong lengths in the chevy section. The chart says my springs are 54". But if you add up the lengths provided it comes out to 52", this matches my own measurements.
Just a heads up to anyone using this chart. It got me for quite a while
Old January 15th, 2012, 11:42 PM   #223
coolgareray
NMU Trailcat Alumni
coolgareray's Avatar
I was getting super bad axle wrap a few years ago, when I pulled everything apart to add some leafs because rough country leafs are garbage and went flat and wrapped because I actually wheeled my Jeep and didn't just pavement pound it, I discovered my center pins looked like a set of stairs. The leafs were shuffling around. I've been running Rough Country 4.5" packs minus 2 leafs with the 3 s10 zr2 springs (the whole pack minus eyelets) and the s10 overload for the last 2? years. It's slightly firm driving around but still flex's and a blazer is def heavier than a cherokee. If I did it again I'd def use explorer leafs like we did on a buddies. They're long and can be cut so they're like running a secondary main. I do still want to run a slightly longer main though. I'm def going 4 link someday leafs suck as you want them flexy but not too flexy so they won't wrap.
coolgareray is offline   Reply With Quote
Old January 16th, 2012, 02:47 PM   #224
VAhasnoWAVES
Dirty South
VAhasnoWAVES's Avatar
Originally Posted by wadey View Post
Walt, if you ever find that ds link let me know
http://www2.dana.com/pdf/J321-CV.PDF
book mark it.
another thing to consider when trying to determine what main leaf you want to run or what you want to do with your springs (rebuld, rearch, replace) is shackle angle. you could pony up for deaver leafs if you wanted to, but if your shackle angle is vertical itll still ride like poop on the street where you really only use a couple inches of travel. on the trail, you want about a 45* angle on your shackle to give you the best of up and down travel. or you could fine tune the angle to get the most out of your shocks while not destroying the body with your tires. its a balance.
also, be sure to get those things that go in between each leaf, or use graphite paint so that they dont squeak.
VAhasnoWAVES is offline   Reply With Quote
Old January 16th, 2012, 03:30 PM   #225
cruzer72
cruzer72's Avatar
So.....
My rear leafs are shot and are allowing bad axle wrap, even on the street. All the wrap has killed my drive shaft, the ears were smashed over the ujoint caps and chipped when I pressed the joint out. I put the new joint in and welded it into place to make it hold. That being said I have 2 weeks to find a replacement before a Snofari.
I have been thinking about doing a hack and tap and running some type of double cardan ds. I'm not sure if this is possible or not. I also haven't been able to find a lot of info on np233 sye. Is there one or does a np231 sye work on the np233?
Ive also been thinking about a slightly longer shaft that fits my slip yoke, maybe a truck shaft? Only reason for being longer is to compensate for the extra shaft I have exposed from the lift.
As for the leafs I have no idea where to even start. I like the flex the stock pack provided but it obviously they didnt hold up. I would like to find a set I can use the stock hangers with. I would also be interested in a set that provides about an inch more lift over a stock pack.
I have lots of ideas, but little time to decide on my options. Any suggestions?
I used the Novak Adapter for a 231 on electric shift 233.I had both T-cases just in case. They are identical. Also did not need any D/C on either shaft.
2015 Wrangler Unlimited
1985 S-Blazer 4 linked, 427ci
1963 Nova SS 350hp I6
1972 Monte Carlo
1993 Tracker 4:1 Case, 33" KM2
cruzer72 is offline   Reply With Quote
Old January 16th, 2012, 04:49 PM   #226
Freak
Wheelin the HD
Freak's Avatar
Did you find one that used the tone ring and sensor for the newer chevies?
Old January 16th, 2012, 05:37 PM   #227
cruzer72
cruzer72's Avatar
Everything still worked speedo wise.
It was in a 96 S-blazer, it has been a few years.
Can't totally recall.
1972 Monte Carlo
Old January 16th, 2012, 07:10 PM   #228
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
book mark it.
Thank you
As for the leafs I just going to replace them with another rebuilt spring that has had an extra leaf added and run a second main leaf, hopefully it will work.
I don't think that will work with the 99 and ups.
Old January 16th, 2012, 08:08 PM   #229
Freak
Wheelin the HD
Freak's Avatar
I was going to put my tone ring on the output shaft of my trans when I was still going to run the 4l60e. It just throws of your spedo off when in low lol.
Old January 17th, 2012, 04:43 AM   #230
coolgareray
NMU Trailcat Alumni
Here's what what my old center pin looked like. what I'm getting at is you may be have more going on than you think. I was sure to retorque my ubolts after I drove it for so long too. maybe I had waited too long before I did.
Old January 17th, 2012, 06:30 AM   #231
GMKLR50
Broke wheeler
GMKLR50's Avatar
i feel your pain, i have the same set up.....I want hydro but I might still want a selectable, dont know what I will do first, or what ill have the money for first.
GMKLR50 is offline   Reply With Quote
Old January 20th, 2012, 12:45 AM   #232
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Thanks Ill be sure to check the bolts but you can see the wave in the spring
Im not sure either both would be ideal but like you said money is always concern.
How do you phase your U joints? Ive tried and they seem to bind more
Old January 20th, 2012, 01:01 AM   #233
VAhasnoWAVES
Dirty South
if your rebuilding your pack, be sure to replace your center pins. $2 isnt much for new bolts.
also look into liners rather than using graphite paint in between your leafs to combat noise. deffinantly a good idea.
Old January 20th, 2012, 01:10 AM   #234
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
I'm not sure what the plan for leafs is right now. I'm not sure Ill have time to replace them before Snofari, which is my main concern. But long term I may just link it. After talking to members of zr2usa the only way to fix axle wrap on these trucks is to order custom springs and build an anti wrap bar. That being said I would rather not spend $500+ for leafs and another $100 for a anti wrap bar, when I could link it instead.
Old January 20th, 2012, 01:27 AM   #235
VAhasnoWAVES
Dirty South
Old January 20th, 2012, 01:36 AM   #236
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
I cant win....
I broke the U joint when I got stuck with only 3wd. I was stuck in a ditch and could only reverse, so I put it in 4low and gave it everything the truck had, while wiggling the front tires being sure not to go to full lock. As you can see joint still failed and took out the both shafts in the process
Randys Ring and Pinion, (overstockdiffparts.com parent company) has given me a return number to warranty my new shafts so its not a total loss. But its a little uneasy to see that I'm breaking blingish parts and I haven't really wheeled it yet. Whats it take to keep this thing together RCV's????????
Old January 20th, 2012, 05:09 AM   #237
BeaverTown
Cuck Fancer
BeaverTown's Avatar
Send a message via Yahoo to BeaverTown
I cant win....
I've still got stock shafts if you need them for snofari. They'd need new joints though. I'm still looking for the superwinch lockouts too. But I've got the spicers for sure.
Sent from my C771 using Tapatalk
BeaverTown is offline   Reply With Quote
Old January 20th, 2012, 11:18 AM   #238
kmanxj5011
kmanxj5011's Avatar
You needs 60's
kmanxj5011 is offline   Reply With Quote
Old January 20th, 2012, 12:32 PM   #239
GMKLR50
Broke wheeler
GMKLR50's Avatar
there not phased, but its still a pain, I havent had as much trouble as you but i dont drive mine that often, Its only a trail rig and its not to bad as long as im moving and on soft ground
Old January 20th, 2012, 03:23 PM   #240
98-S10-lifted
98-S10-lifted's Avatar
Sweet build! Can't easily tell from the pics, but did you leave the axles full width? How far do they stick out from the flares? Thinking about putting my BlaZeR2 through the swap.
98-S10-lifted is offline   Reply With Quote
Page generated in 0.42741 seconds with 84 queries
