D44 front, ford 9 inch? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old December 11th, 2005, 02:55 PM   #1
Chop
Mischievous Badger
Chop's Avatar
Default D44 front, ford 9 inch?
i might be getting a D44 front 8 lug. but i have a 9 inch rear axle with the 5x5.5 bolt pattern can i change the 9 inch to an 8 lug or would it be cheaper to change the D44 to a 5 x 5.5 ??
also is there any write ups or information on both of those options??
yes i have searched
Old December 11th, 2005, 04:37 PM   #2
sodapop
Support the Sport!
sodapop's Avatar
I've not researched the price but I'm betting that it would be cheaper to do the front. DO you already have rims for 5 on 5.5? Cuz that would save some cash too. For the 44 they cam in 5 on 5.5, 5 on 4.5, 6 lug and 8 lug versions. Earlier fords like 71-77 broncos were 5 on 5.5 as were 78-79 Ford Bronco, F-150, F-250, 74-80 front scout II's
You should be able ot find rotors from one of those models that will fit your spindle and junk. It might help folks to know where this 8 lug is comign from to give you an even more specific answer.
Old December 11th, 2005, 05:00 PM   #3
Chop
Mischievous Badger
Chop's Avatar
its an old ford 8 lug from a 76
Old December 11th, 2005, 08:08 PM   #4
smasheromalley
smasheromalley's Avatar
Dodge 1/2 tons all used 5 on 5.5 dana 44s too. The pre 94 ones anyhow. Theres gotta be about a billion of them things laying around.
Old December 11th, 2005, 08:41 PM   #5
JohnnyJ
Low Range Drifter
JohnnyJ's Avatar
check this out
My recommendation would be to take of the 8-lug parts and put them on the shelf. Do not sell them. Then, if you want to upgrade to a 14-bolt, d60, or d70, you'll have the parts in hand.
If you have not plans for high-steer, go pull the knuckles out off any old ford d44 (ttb is fine), grab the outer shafts.
If you want high steer (or the option to use it later) find a set of chevy or FSJ flat top knuckles and the small bearing spindles, and use the ford parts listed in the link and go that route.
JohnnyJ is online now   Reply With Quote
Old December 11th, 2005, 09:05 PM   #6
Chop
Mischievous Badger
Chop's Avatar
nice thanks bud
Old December 12th, 2005, 01:02 PM   #7
noodles
give 'er sh*t ay?
noodles's Avatar
Originally Posted by Jeepinlunatic
nice thanks bud
with the dodges, they use a preassembled wheel bearing, that you can just switch out to the 5 on 5.5
Old December 25th, 2005, 07:26 PM   #8
1993Bogger
1993Bogger's Avatar
i have set of knuckles from a D44 that are 5 x 5.5 for cheap if you want them
1993Bogger is offline   Reply With Quote
Old December 25th, 2005, 07:33 PM   #9
Chop
Mischievous Badger
Chop's Avatar
what are you looking to get for them and where are you from
Old December 25th, 2005, 08:50 PM   #10
1993Bogger
1993Bogger's Avatar
i would take $50 and I am from nothern NY
Old December 25th, 2005, 09:18 PM   #11
rdnkjeeper
Send a message via Yahoo to rdnkjeeper
Default 44 & 9"
I am getting ready to put this set up in my Jeep. I am going to change the front to 5 on 5.5. I
Good Luck
rdnkjeeper is offline   Reply With Quote
Old December 25th, 2005, 09:41 PM   #12
Chop
Mischievous Badger
Chop's Avatar
thats not bad if i find an axle i need to change over i will let you know
Old December 25th, 2005, 11:12 PM   #13
Icebreaker88
Icebreaker88's Avatar
I dont thinck TTB 44 knuckles will not go on a solid 44.
[QUOTE=TurdBronco;1095911]I don't usually race cause it is still a focus.[/QUOTE]
Icebreaker88 is offline   Reply With Quote
Old December 26th, 2005, 12:57 AM   #14
Mclovin
"The Situation"
Mclovin's Avatar
The later dodges like yours... my dodge 44 doesnt have a preassmbled POS hub...
Page generated in 0.33640 seconds with 65 queries
