1953 Willys truck build. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 15th, 2011, 10:30 PM   #1
bjkttr
bjkttr's Avatar
Default 1953 Willys truck build.
Ok I have a 1953 willys truck that I just acquired. I am going to start from the from the ground up. So I need a little help before starting. I have the original frame but it has some rust and rust through in the middle of the frame. Should I just repair it and call it good or should I do a frame swap with a chevy short box truck frame? My plan is to put a dana 60 in the rear and for now just a dana 44 in the front for now. I have a ford 390 fe that is already built that I want use for the engine. ( I know I get told all the time that it is a lot of weight to deal with) I have the engine already and really don't want to spend to money on a different engine right now. Any help would be appreciated I want to get rolling on this project.
bjkttr is offline   Reply With Quote
Old July 16th, 2011, 08:56 AM   #2
1x1_Speed_Craig
Simplify...
1x1_Speed_Craig's Avatar
Congrats on the project. Pics of the frame rust would help a great deal in getting input from folks. Post some up when you can.
Craig
Old July 16th, 2011, 04:15 PM   #3
bjkttr
bjkttr's Avatar
picture are up
Old July 16th, 2011, 04:33 PM   #4
schanxj
schanxj's Avatar
Congrats on the 390FE, had one in a 66 galaxie. Although more expensive to build than a small block they are much easier. With an aluminum intake you shave off around 90# right there. Mine made really good power for the size of the car.
schanxj is offline   Reply With Quote
Old July 16th, 2011, 07:00 PM   #5
ovrlnd
HURL SCOUTS
ovrlnd's Avatar
blast the frame. fix the rot and box it.
Old July 17th, 2011, 11:41 AM   #6
bjkttr
bjkttr's Avatar
Thanks for the advise I will start tare down this week and get it blasted.
Old July 26th, 2011, 06:28 PM   #7
bjkttr
bjkttr's Avatar
So i have taken every ones advice and decides to get the original frame blasted and fix it. I have just removed the bed and now on to the cab. This will most likely be a slow build do to time and money. I just hope everyone bares with me because I am sure that I will have a lot of questions along the way.
Old August 15th, 2011, 08:28 AM   #8
chriszildjian17
chriszildjian17's Avatar
can i help.lol
chriszildjian17 is offline   Reply With Quote
Old August 15th, 2011, 08:41 AM   #9
bjkttr
bjkttr's Avatar
I guess.
Old August 15th, 2011, 09:05 AM   #10
chriszildjian17
Picked up some free 1/2 steel plate for you today for free.
Old August 15th, 2011, 09:07 AM   #11
bjkttr
bjkttr's Avatar
that's cool
Old August 29th, 2011, 11:53 AM   #12
bjkttr
bjkttr's Avatar
We got the cab removed and we just finished the frame repair work. next step get some parts ordered and get the frame sand blasted. Here are some current pictures.
Old August 29th, 2011, 11:59 AM   #13
1x1_Speed_Craig
Simplify...
Nice repair work!
Page generated in 0.19367 seconds with 62 queries
