dana 30 "high steering" suggestions - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 16th, 2006, 08:28 PM   #1
greenmeanie
greenmeanie's Avatar
Default dana 30 "high steering" suggestions
i have a yj wrangler with a dana 30. i did a spring over and need to mount my drag link on top of the springs; and preferably leave the tie rod where it is. i made a tower from the old mounting point on the tie rod straigt up; that did not work. i need something that is inexpensive, doesn't require changing the knuckle style, and is tough. let me know if you have any tips please!! i want to get this thing going this week....
greenmeanie is offline   Reply With Quote
Old September 16th, 2006, 09:05 PM   #2
Noah's Ark
Noah's Ark's Avatar
PM sent!
Best way to go is the Tera Knuckle though for the D30. There is not a "strong, safe" way that is easy and inexpensive. Is this a daily driver or trail rig?
Noah's Ark is offline   Reply With Quote
Old September 17th, 2006, 12:50 AM   #3
PavementPounder
PavementPounder's Avatar
That's easy - put the Jeep back the way it was.
Seriously, if you weren't prepared to do this the right way you shouldn't have done it at all. If you're going to stick with the 30, I agree with Noah's Ark. Otherwise, I would suggest a 78-79 F-250 HPD44. Its already SOA, already has flat-top knuckles with the driver's side studded, and has the same spring perch width as a YJ.
Old September 17th, 2006, 01:09 AM   #4
Mongo
Mongo's Avatar
Mark,
what side is the drop on those?
Mongo is offline   Reply With Quote
Old September 17th, 2006, 06:16 AM   #5
PavementPounder
Originally Posted by dads95yj
Mark,
Driver! They are typically found with a D60 rear, so you just use both and buy 8-lug rims. This is what Leanz is running, except she's afraid of heights and is going SUA.
I've yet to see passenger HP anything except for what looked like a HPD80 under a Kodiak that I haven't found printed evidence of yet.
Old September 17th, 2006, 02:15 PM   #6
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
Originally Posted by Noah's Ark
PM sent!
Well close...
The BEST, CHEAPEST way is to find a WJ front axle in a junk yard (or all the outers.) Then you get crossover steering and nice big brakes.
Here in an old article I wrote that is missing the pictures....
http://www.evilmonkeymedia.com/dl/Wjsteering.htm
It was a NIGHT and Day difference. I put up with stock steering SOA for about a month before I had to get rid of it...
This is the 85mile ride home after the install at Brians house...
The EASIEST way would probably be the Tera Kit because you don't have to source parts and such.
JcrOffroad
Zoom Zoom!
Old September 17th, 2006, 04:23 PM   #7
PavementPounder
How much did that setup run you?
Looks like a lot of room - is there enough space under the springs for the tie-rod to be flipped?
Old September 17th, 2006, 04:39 PM   #8
Kawierider
Kawierider's Avatar
Now, to play devils advocate because I havent looked to closely at my knuckles in awhile.
I have an XJ, If I remember correctly the top of the knuckles IS flat, or pretty close. What would keep you from drilling out the knuckle and reaming a taper in to use a larger diameter tie rod or heim joint similar to the JCR kit (although I think you'd need larger diameter hardware than that to make it work)
Old September 17th, 2006, 05:02 PM   #9
PavementPounder
Originally Posted by Kawierider
What would keep you from drilling out the knuckle and reaming a taper in to use a larger diameter tie rod or heim joint similar to the JCR kit?
Probably using the term "flat top" in reference to the correct area of the knuckle. The "top" is the area up by the ball joint. I may be misunderstanding you, but it sounds like you are talking about the top surface of the knuckle arm for the purpose of flipping the tie-rod on top. That area is not what the term "flat-top" is used to describe on a knuckle.
Old September 18th, 2006, 12:36 AM   #10
Monkeyevil
I <3 Miatas
Monkeyevil's Avatar
It was close, but no. I could have added a spacer on the springs and fit it, but that would have just been ghetto. Another problem would have been reaming the arms from the top on the passanger side with the upper arm in the way. All in all it wasn't worth the trouble to me.
I spent $150 on the knuckles, caliper mounts, calipers, and rotors. $50 on pads (my akibunco pads were way more $$ than teives style ) Built the spacers with the plasma cutter, then the steering rods and TRE's cost about $150 or so.
So a good $350 for better steering AND WAY better brakes. Less than setting up the brakes and steering on my d44 that is for sure
JcrOffroad
Zoom Zoom!
Old September 20th, 2006, 08:36 AM   #11
ckupq
Kitten I'm gonna eat you!
ckupq's Avatar
If you want to keep a 5 X 5.5 axle find the ones out of the extended cab f150's of the same model year they are spring over and have 5 bolt hubs.
ckupq is offline   Reply With Quote
Old September 20th, 2006, 10:24 AM   #12
PavementPounder
Go through the 1st two links here to see the differences in all these axles.
Page generated in 0.85991 seconds with 59 queries
