Need help identifying 14 bolt axle with disc brakes - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 10th, 2011, 10:14 AM   #1
broke33
Default Need help identifying 14 bolt axle with disc brakes
I purchased a 14b with what looks like factory disc brakes but it came without the rotors and calipers. I wantt o try and identify it so I can buy rotors calipers, brakes, etc... CAn any body help me with the year and make this may have come out of? The axle details are as follows:
Numbers on carrier housing:
CFD
135
3977323
From this it looks like the older style (pre-87) with drums but the pics below look like a factory disc style:
broke33 is offline   Reply With Quote
Old July 10th, 2011, 10:15 AM   #2
bigbchevy
missmrgreenagain
bigbchevy's Avatar
are you sure its a 14bolt?
H.o.r.e
Old July 10th, 2011, 10:25 AM   #3
broke33
According to the numbers on the housing its a 14 bolt and there are 14 bolts in the dif cover
Old July 10th, 2011, 11:23 AM   #4
tw1st3d5
tw1st3d5's Avatar
If it is stock gears, the date should be stamped in the ring gear.
Old July 10th, 2011, 11:41 AM   #5
HVYRTFT
Reed my teef
HVYRTFT's Avatar
post a picture of the cover.
Old July 10th, 2011, 11:47 AM   #6
littletrucker
I'd hit that
littletrucker's Avatar
Post a picture of the housing as well- it kinda looks like one of the newer style where the rotor slips over the hub instead of pressed on behind the hub like the older style
Old July 10th, 2011, 11:48 AM   #7
boggin-machine
boggin-machine's Avatar
thats not a 14 bolt by the looks of the pumpkin that i can see.
Old July 10th, 2011, 01:45 PM   #8
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
looks way to round
bbrancheau is offline   Reply With Quote
Old July 10th, 2011, 01:57 PM   #9
boggin-machine
Originally Posted by bbrancheau View Post
looks way to round
correct also.
also they didnt know a 14 bolt a 14 bolt cause of the bolts in the diff cover.
Old July 10th, 2011, 02:00 PM   #10
broke33
It has the pinion support and the BOM matches.. it looks, smells, walks like a 14b....
Old July 10th, 2011, 03:41 PM   #11
yyj87
yyj87's Avatar
WIKI
yyj87 is offline   Reply With Quote
Old July 10th, 2011, 03:42 PM   #12
Tab
Tab's Avatar
def not a newer style where the disc's would be standard. Mine is a "new style" and there is a ton of ribbing on them and most of the fastners are metric.
Old July 10th, 2011, 03:42 PM   #13
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
well yep it sure is. older one too.
Old July 10th, 2011, 07:09 PM   #14
broke33
I figured it out (spent ALOT of time on google). It has a 1/2 backing plate on it from the front d44 or 10 bolt. This is used for a common 3/4 ton caliper and rotor disc brake conversion. I just need to get the calipers and rotors.
Page generated in 0.34412 seconds with 65 queries
