wiring question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 9th, 2011, 11:06 AM   #1
CHEROKEEMUDMAN01
mellow yellow
CHEROKEEMUDMAN01's Avatar
Default wiring question
i did put a 318 in my 89 jeep xj. it runs fine but the part that bothers me is how many things i had to hook up the trucks run/key on power line. i dont want to overload or cause a fire and i would like to hear some opions if this is to much and how to fix the prob. this is what i have being powered off that line with is a 14 gauge i believe or maybe a 12 and in my jeep it is the solid yellow wire.
mopar ingition box
ballist resistor
electric choke for carb
a wire to turn on a 40 amp relay for electric fans (not powering fans)
i didnt know if this would possibly overload the wire. also thought about adding a relay to the key on power line to motor compartment but didnt know if it would affect the electronic ingition or if it was even needed. thanks for any help
CHEROKEEMUDMAN01 is offline   Reply With Quote
Old July 9th, 2011, 01:25 PM   #2
CHEROKEEMUDMAN01
mellow yellow
anyone? i would really appricate any imput
Old July 12th, 2011, 05:40 PM   #3
CHEROKEEMUDMAN01
mellow yellow
no imput from anyone?
Old July 13th, 2011, 09:26 PM   #4
YFZdude
aka Mike
YFZdude's Avatar
Well I'll put my two cents in since no one else seems to be speaking up.
If you don't blow fuses when you power it on, then you don't have a major problem.
If you are loading the circuit almost to the max of what the fuse can handle then it will blow when the wire gets hot enough. Then you know you have just a bit too much current flowing.
Usually the fuses that are the default values are safe for the wire gauge installed. Good rule of thumb...
Small Wire + Big Fuse = Very Bad
Big Wire + Small Fuse = No Worries
Find the middle ground if you need to, but you can't always just use a bigger fuse without knowing what the wires can handle.
YFZdude is offline   Reply With Quote
Old July 13th, 2011, 11:36 PM   #5
Yota Bill
do you have a multimeter capable of reading amerage, or an amp clamp? You can get those pretty cheap at Harbour freight, good enough for occasional DIY use.
I would measure the total load and compare that to what the wire is capable of, but you'll have to determine the actual size of the wire to find what its rated for, and also dont forget to leave a margin of error for safety. 10-15% should be enough.
If you are pushing the limit of the wires capacity, then measure the current to each device and see which ones you can run off of it safely. I'm thinking the ballast is the highest load, and you could easliy run that through a relay to remove the load from the original wire. Honestly though, you are probably safe with what you have now.
Old July 25th, 2011, 05:54 PM   #6
CHEROKEEMUDMAN01
mellow yellow
thanks for the info guys i will pick up a multimeter this week and give that a try and see how it looks.
Old July 26th, 2011, 12:20 AM   #7
Elvis13
I do believe you need to break the circuit to measure amperage, its not like reading volts. In case you didn't know.
Old July 26th, 2011, 09:17 PM   #8
YFZdude
aka Mike
YFZdude's Avatar
Correct. Measuring current requires the meter be in series. Meaning you have to make the electricity flow through it on its way to the load.
And most meters require you to plug the positive lead into a different jack to measure amps as well.
Page generated in 0.27671 seconds with 47 queries
