2003 F150 4x4 won't engage - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 8th, 2011, 12:42 AM   #1
chevyk10
FORD / GM
chevyk10's Avatar
Default 2003 F150 4x4 won't engage
I guess I'll try to explain this the best I can. My girlfriends 2003 F150 won't go into 4x4 unless you turn the wheel all the way to the right at a dead stop and hit the gas. Sometimes it even takes a few trys and only works about 60% of the time. I've tried everything including putting it into neutral before switching it into 4 wheel and nothing happens. Its got that bullshit switch on the dash for the 4x4 with the stock auto locking hubs. Any ideas what could be causing it to not want to engage? I'm use to the old manual lock outs and floor shift 4x4 so don't know much about this stuff. Its got 235k miles so I'm guessing something is starting to wear out?
chevyk10 is offline   Reply With Quote
Old July 8th, 2011, 05:41 AM   #2
88fordman
88fordman's Avatar
is the tcase going in but the front end is not? that would be my guess. if so just do yourself a favor and install some superwinch manual hubs on it. they are cheaper and better than OEM. then you will have manual hubs that you have to lock in just like 'ol days.
88fordman is offline   Reply With Quote
Old July 11th, 2011, 01:27 AM   #3
Never_Evil
2003 fords do not have traditional hubs.
Is the ABS light "on" on the dash? If so, you may need to replace the unit bearing assembly on each side.
There is also a set of relays that must click on to engage the 4wd system. Check the relays and electrical.
Old July 11th, 2011, 01:27 AM   #4
Never_Evil
Old July 13th, 2011, 10:22 AM   #5
chevyk10
FORD / GM
chevyk10's Avatar
I don't know much about newer 4wd systems, but you can hear it click. As far as the ABS light goes I'll have to get back to you on that. I just doesn't seem like the front end wants to lock in for some reason.
Old July 13th, 2011, 11:54 AM   #6
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Front axle actuator
Old July 13th, 2011, 04:17 PM   #7
masterbeatty
masterbeatty's Avatar
Originally Posted by Jeeperz Creeperz View Post
Front axle actuator
x2 my expedition had the same problem. they work off of vaccume, there are relays and all the vac lines pass side fender by the power box. very rarely do the tcases have issues of not going into 4wd in my experiance. start with making sure the actuator is free and can move then hit 4x4 and pull the vac lines and make sure one has vac. also if those get swapped around at the actuator, when you hit 4x4 the front end actually disengages, ask me how i know haha 4 hrs of being stuck. if you need help let me know ive delt with those alot. and im right in hartland i can come help you
Old August 16th, 2011, 10:49 PM   #8
chevyk10
FORD / GM
chevyk10's Avatar
lol alright thanks man. I'll have to check it out whenever I have time which isn't very often anymore. I figured it would be something easy like a bad vac line or something.
Page generated in 0.25653 seconds with 47 queries
