DRW or SRW front d60 hubs - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 4th, 2011, 08:30 PM   #1
Bruster
Default DRW or SRW front d60 hubs
Looking to do after market drive flanges where im able to remove the pucks.I have the dodge hubs/flanges now.Question is what will be the better choice between DRW or SRW chevy hubs if im planning on recentered H1 wheels from trail worthy fab.
Thanks ,
ERic
Old July 5th, 2011, 08:41 AM   #2
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Thanks ,
ERic
What do you want your track width to be? The DRW is wider than the SRW.
Old July 5th, 2011, 03:47 PM   #3
Bruster
Right now im at 83 inches wide.Figure the srw hubs will work just fine.with 3.5 inches of bs
Old July 5th, 2011, 05:41 PM   #4
bigblockford79
Big Block Ranger
bigblockford79's Avatar
FYI, With DRW hubs and stock H1 wheels you will sit at approximately 88" wide. If you re-center the wheels your only logical option is SRW hubs.(unless you want to be uber-wide).
Old July 5th, 2011, 06:27 PM   #5
Bruster
yup..after reading a bit on pirate ive come to that conclusion.Wheels will be re centered from trailworthy fab.
Thanks for the help
Page generated in 0.17084 seconds with 38 queries
