F150 SAS Truggy - Page 9 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 3rd, 2013, 03:12 PM   #161
Strangler
Strangler's Avatar
Your truck is sweet. Lower it like 20 inches and all will be well with the world!
Old March 3rd, 2013, 05:28 PM   #162
jeepxj2007
Send a message via AIM to jeepxj2007
Lol...20 inches would give me 8 inches of ground clearance in the belly and I could listen to some low rider by war...it is tall but the no fenders with the tube up front blows it a little out of proportion until you are next to it...don't get me wrong its high but not what the pictures make it out to be....plus with a SAS on these years trucks you need at least 4-6 over stock to clear the engine cradle which I didn't really want to get rid of.
Sent from my Galaxy Nexus using Tapatalk 2
jeepxj2007 is offline   Reply With Quote
Old March 7th, 2013, 08:47 PM   #163
jeepxj2007
I have my radiator mount almost finished up. I think I am going to take a small piece of angle and stitch it down to the top plate of the radiator mount to stiffen it. I was suprised how much the 1/4" flatbar would give under not a whole lot of pressure on the adjusting rod. Here are some pics of it. The radiator is isolated between the steel in all clamping portions by 1/4" thick rubber.
Old March 11th, 2014, 12:12 AM   #164
chasetheface123
chasetheface123's Avatar
Well, I figured I would bring this thread back to life. I ended up purchasing the truck with intentions of finishing it up to replace my ranger that I had last year. Plans for it include
Fuel injection
Air shocks in the rear
Airs/coilovers uo front but still undecided
Swapping a 60 in eventually
Throwing some more tube in the cage to fill in some voids
Winch
Possibly switching the front to a 4 link so I have an excuse to do full hydro
Progress on it has been slow. I purchased a propane setup off a guy on Craigslist without even realizing that it was all seized together and in need of a full rebuild. I had another 351w out of my bronco that I was building with the computer/wiring harness, and intakes so tonight I swapped that all over. Still waiting to mount my other two tsls and putting them on the rear. Here are a few updates though.
chasetheface123 is offline   Reply With Quote
Old March 11th, 2014, 12:24 AM   #165
chasetheface123
Old March 11th, 2014, 12:26 AM   #166
chasetheface123
That's pretty much progress from when I got it until now. Forgot to mention I went and picked up my old 2.0 16" fox airs for the rear from feva4u a few days back. Thanks Brandon for keeping them nice and warm in your garage. Hoping to lower this thing down 6-8"
Old March 11th, 2014, 05:27 AM   #167
yukonjake
yukonjake's Avatar
I like it looks pretty sweet the way it is
yukonjake is offline   Reply With Quote
Old March 11th, 2014, 08:31 AM   #168
chasetheface123
It's just too damn tall
I had a nice truck once. Then I let a buddy borrow it...
Old March 11th, 2014, 08:54 AM   #169
Wramblerguy
Wramblerguy's Avatar
Square rear driveshaft?
3rd generation jeeper
Old March 11th, 2014, 08:55 AM   #170
chasetheface123
It's Just temporary. Cheap and easy to get it moving around for the time being
Old March 11th, 2014, 08:56 AM   #171
Wramblerguy
I like it lol
Old March 11th, 2014, 08:58 AM   #172
chasetheface123
It's 2.5/.250 wall outer and 2.0/.250 inner.
I didn't even consider balancing it because it won't ever see street, and probably won't ever go over 30-35. Although it is pretty square (no pun intended). It would take quite a bit to bust it..
Old March 11th, 2014, 09:05 PM   #173
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
What was this nice truck that you used to have?
Old March 11th, 2014, 10:43 PM   #174
chasetheface123
Funny...
Old March 16th, 2014, 09:43 AM   #175
chasetheface123
Made a little progress this weekend, got my tires mounted and switched around finally. Also started on the dash. Cut out a couple small pieces of 20ga to fill in the voids and a place to put my gauges, battery disconnect, and push button start. I'm still trying to figure out where to mount my battery and 6al. Any pros or cons to mounting them directly in the cab?
This week we are getting the rear end mocked up for my air shocks, hopefully lowering it down at least 6".
Old March 16th, 2014, 09:59 AM   #176
mitch52
mitch52's Avatar
lookin good ill have to check it out when im up there
mitch52 is offline   Reply With Quote
Old March 16th, 2014, 10:35 AM   #177
chasetheface123
Swing on over when you're back and you can help me figure out a center console, as well as where to put my shifter, twin sticks, and cutting brakes.
Old March 20th, 2014, 12:01 AM   #178
chasetheface123
Started on the rear hoops tonight.
Old May 12th, 2014, 11:54 PM   #179
chasetheface123
Slowly making progress getting it back down to the height it should be at. Made a set of shock hoops and tabs for the rear but it still needs to go down another inch or two in the rear. Started adding to the cage as well, because I need a spot to hide the propane tanka out if harms way. Here's a few pictures. Any input as far as the cage lines that I have taped off?
Old May 12th, 2014, 11:56 PM   #180
chasetheface123
Page generated in 0.61980 seconds with 84 queries
