04 1500 no 4x4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 3rd, 2011, 01:29 PM   #1
HVYRTFT
Reed my teef
HVYRTFT's Avatar
Default 04 1500 no 4x4
tried auto, 4hi, 4lo. nothing. Do these style trucks have the front axle actuator like the older ones had? Can you check them with a multimeter? Thanks!
Old July 3rd, 2011, 01:34 PM   #2
bdd1469
bdd
bdd1469's Avatar
Ya you may have a bad actuator,i've replaced several of those with the newer update from gm.im sure you can buy them any where.
Old July 3rd, 2011, 01:38 PM   #3
bdd1469
bdd
bdd1469's Avatar
Put it in 4 hi and see if you can spin the front driveshaft with the front end jacked up.if you cant, the actuator or something else in the axle is bad,if the drive shaft spins,its in the t-case/linkage.
Old July 3rd, 2011, 01:43 PM   #4
bdd1469
bdd
bdd1469's Avatar
I shoulda read that closer,thought it said 94 chevy.dont know about a 04,if it doesnt go to 4 low,as in no low range it would be a t-case shift motor i would think.but im sure someone knows more then me,and will help out.
Old July 3rd, 2011, 01:45 PM   #5
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
Just my .02, but i've that the switches are pretty common to go bad. The 4x4 dash switch that is
Old July 7th, 2011, 01:14 PM   #6
jjoz05
BARE BONES OFFROAD
jjoz05's Avatar
When you ture your key all the lights should flash then go off and then light up whatever gear its in. If they dont it could be the switch on the dash.
jjoz05 is offline   Reply With Quote
Page generated in 0.20466 seconds with 41 queries
