52" spring swap????? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 30th, 2011, 09:58 PM   #1
bjkttr
bjkttr's Avatar
Default 52" spring swap?????
Has any one do a 52" spring swap on a chevy? How bad is the swap and how is the ride? and what benefit is there to just buy a lift kit?
bjkttr is offline   Reply With Quote
Old July 1st, 2011, 10:14 PM   #2
Red97
http://diy4x.com/cart/index.php?rout...product_id=120
here is a link to the swap parts. they also have a kit for the 81 and newer trucks. the 52s flex a lot better and ride better as well because you dont need as much arch in the spring to get the desired lift height.
Red97 is offline   Reply With Quote
Old July 1st, 2011, 10:22 PM   #3
bjkttr
bjkttr's Avatar
Thanks that is a lot of help.
Old July 30th, 2011, 09:55 PM   #4
TanTahoe
TanTahoe's Avatar
If you want to go the cheap way, you can also cut out rivets that hold your front body mount in place and swap them side to side. This will give you the extra couple of inches for the front mount. Then just move rear mount back as well.
TanTahoe is offline   Reply With Quote
Old August 1st, 2011, 02:08 PM   #5
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
http://coloradok5.com/52inchspringswap.shtml
Old August 1st, 2011, 08:04 PM   #6
koochman450r
koochman450r's Avatar
Originally Posted by Hoss Blazer View Post
thats a well laid out swap post there. I need to do that to my cheby! Any one have some 52'' springs laying around?
you won this battle.
Old September 9th, 2011, 10:56 AM   #7
DUNE JUMP
DUNE JUMP's Avatar
I probably have a pair of main leaves and enough other leaves to make up a bastard pack. PM me if you want to try.
Came out of my '76 K5 rear.
Page generated in 0.20687 seconds with 44 queries
