ZJ shaft in a TJ - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 20th, 2011, 11:55 AM   #21
littletrucker
I'd hit that
littletrucker's Avatar
I have heard of people running the cv style and having good luck with them
Old July 20th, 2011, 11:59 AM   #22
2fst4you
2fst4you's Avatar
They going to hold up better then a ujoint shaft on 35s locked
Old July 20th, 2011, 12:03 PM   #23
ajmorell
Stock v. stock the u-joint shafts are stronger. If you upgraded to RCV's then yeah they are a lot stronger than the stock u-joint shafts.
Old July 20th, 2011, 02:28 PM   #24
2fst4you
2fst4you's Avatar
Ok I don't want cvs then not gonna put rcv's in a d30 lol
Old September 5th, 2011, 10:57 PM   #25
2fst4you
2fst4you's Avatar
Can I run a 93 xj shaft in my tj? I know there vacuum disconnect and have the smaller ujoints but does that matter? I can change the ujoint size to the bigger 270x correct....
Old September 6th, 2011, 12:00 AM   #26
wadey
┌∩┐(Ú_ů)┌∩┐
wadey's Avatar
You canít run that shaft because it is a 2 piece shaft and requires a vacuum actuated collar to engage/disengage the axle.
I would run the ZJ shaft from AutoZone. If it broke you can still drive on it to some degree, as it wonít bind up as you drive. Remember the drive from the dunes to the campground
The best part is that it carries a life time warranty, which I know you will use
Old September 6th, 2011, 02:02 AM   #27
2fst4you
2fst4you's Avatar
That's what I was thinking. I don't want a cv style shaft tho
Old September 6th, 2011, 09:33 AM   #28
Sandals
Fucking Zen as Shit
Sandals's Avatar
Why not just get a moser shaft?
or another TJ one?
Old September 6th, 2011, 09:40 AM   #29
2fst4you
2fst4you's Avatar
What's a moser shaft? I'm trying to find a used tj shaft for a trail spare. I need both inners and outers
Page generated in 0.19769 seconds with 50 queries
