Tow Rig Fuel Economy Database - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 30th, 2011, 03:02 PM   #21
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Originally Posted by Klumpper View Post
Yes, in an ideal world were the throttle angles and engine loads are low, ignition is at an advanced enough to take advantage of it, and engine speed is low enough to not suck lots of air. 4.10's and a 4l80 trans on the highway don't allow it.
I didn't purposely disable the EGR... Doing the intake gasket job the L31's need frequently crushed the EGR hose, and michigan salt + plow truck duty cycle doesn't allow for removing the hose from the manifolds.... fml. Consequently, the mileage did not drop from the blown intake gasket state + egr to the good intake gasket state -egr.
michigan salt-> <- me
When the 8.1 goes in I fully intend on doing experiments with and without EGR and EFILive. But i need to come up with 2k and 200 hours of free time.
LOL, good man.
@clarkstoncracker
Old June 30th, 2011, 03:52 PM   #22
mschaffer66
mschaffer66's Avatar
I want to play, but if I actually calculate out how shitty the mileage is I may kill myself...lol
Old June 30th, 2011, 04:15 PM   #23
Mclovin
"The Situation"
Mclovin's Avatar
Truck:
2006 GMC 2500HD ECSB
Drive:
4WD
Engine:
6.0 gas
Trans:
4L80E
Axle ratio:
4.10:1
Tires:
285/75/R16 Toyo Open Country AT Load D
Mods:
K&N "FIPK II" Load Lifter 5000 air bags
Best Fuel Economy Empty (5500lbs):
15mpg hwy
Best Fuel Economy Loaded (10,500-11,000lbs my best guess):
8.7 around 100 miles each way
Load / Driving:
18' steel deck open car hauler with my s10 truggy on the back and quad
Old July 2nd, 2011, 04:01 PM   #24
scottie
Eye candy
scottie's Avatar
Truck:
2006 Toyota Tundra Reg Cab
Drive:
1WD
Engine:
4.7L VVTi
Trans:
5 spd auto
Axle ratio:
3.92:1
Tires:
265/70/16
Mods:
Pinstripe and some StickerZ
Best Fuel Economy Empty (4100 lb):
23 mpg avg is usually upper teens
Best Fuel Economy Loaded (~8500 lb combined):
14 mpg flat ground, mountains suck so it's not uncommon for it too guzzle petrol.
Load / Driving:
Samurai on 16' trailer + tools no cruise so i usually go 60-75 depending on southerns and my attention span.
scottie is online now   Reply With Quote
Old July 3rd, 2011, 12:18 PM   #25
Kane
Got Jeep?
Kane's Avatar
While drafting a semi, (which I try to do as often as possible).
It's not drafting, it's tailgating, which is unsafe and illegal.
Kane is offline   Reply With Quote
Old July 3rd, 2011, 12:56 PM   #26
Nuggets
I fix stuff!
Nuggets's Avatar
Truck:
1994 Ford F350 dually
Drive:
2WD
Engine:
7.3L turbo IDI
Trans:
auto
Axle ratio:
4.10:1
Tires:
215/80 16
Mods:
No muffler, injection pump turned up
Best Fuel Economy Empty (7100lb):
15
Best Fuel Economy Loaded (15,500 lb combined):
12.5 (summer) 10 (winter)
Load / Driving:
3000# 1985 Audi 4WD rallycross car on top of a 6500# equipment traler
Note: Truck has 302k on the clock and has been shown no love by previous owners.
Old July 4th, 2011, 08:14 AM   #27
Brods
Lol.
Brings up a good point, of the claimed mpg numbers which are hand calculated (and has the speedo/odometer has been verified for accuracy with a gps or by some other means) and which mpg numbers are taken from the manufacturer's lie-o-meters?
Old July 4th, 2011, 09:34 AM   #28
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
Depends on manufacturer - I know GM's FE calc is within 2&#37; if the stock tire size is used.
@clarkstoncracker
Old July 4th, 2011, 12:37 PM   #29
Bones
Bones's Avatar
I don't know about Ford's FE calcualtor, but regarding the speedometer, Ford spec is 0&#37;-4% UNDER at 60 mph. IE if your speedo says 60, you are going 56-60 mph. We will not put your actual speed over your indicated speed.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old July 4th, 2011, 02:32 PM   #30
DuffMan
Your Message Here
DuffMan's Avatar
When I hand-calced FE, my factory lie-o-meter has been pretty accurate (i.e. tighter than +/- 5&#37;).
Old July 4th, 2011, 03:03 PM   #31
dfm_13
dfm_13's Avatar
my dads truck lol:
2004 3500 ram cummins
Drive:
4wd
Engine:
6 cly 24 valve
Trans:
auto
Axle ratio:
stock
tires:
stock
Mods:
stock
Best Fuel Economy Empty:
21 mpg
Best Fuel Economy Loaded (truck plus 13,500 fifth wheel and 1,300 boat behind that):
11-13 mpg
Load / Driving:
35 ft fifth wheel and a 17 ft boat, cruise is normally on 68.
dfm_13 is offline   Reply With Quote
Old July 4th, 2011, 03:23 PM   #32
MilwaukeeF350
Dan
Since I bought tons f250/f350s so I doing list trucks that was good.
truck :
1987 f250 reg
Drive:
2wd
Engine:
6.9L V8 diesel IDI NONTURBO
Trans:
T18 4 speed
Mile:
Unknown could be 157 or 257 or 357K miles
Axle ratio:
3.55
stock tires:
235/85/16
23 mpg but it alway load with tools. 1000 pound Speed were 60 mph
Best Fuel Economy Loaded (truck plus dump trailer/ 5k pound concrete) Estimated 13,500 pound
Load / Driving: 13 mpg
Truck:
1999 F250 reg
Drive:
2wd
Engine:
5.4L V8
Trans:
auto 4R100 it slipping
Miles:
246,000
Axle ratio:
3.73
tires:
235/85/16
Empty it about 5400 pound. Best mileage down highway 60 mph. 17 mpg.
On speed limiter it got 16 mpg with 1200 pound of brick in bed.
Best Fuel Economy Loaded (truck plus trailer/ 9,700 lb F350 dually box) 16,700 pound at scrap weight scale. It got 5 mpg rpm were 3500 most time.
Old July 5th, 2011, 10:59 AM   #33
kickstand
circling the drain
kickstand's Avatar
Old July 7th, 2011, 10:59 AM   #34
Smiley
Smiley's Avatar
Truck:
2001 Ford SD F350
Drive: 4x4
Engine: 6.8L v10, 3" Flowmaster cat-back exhaust
Trans: 4-speed auto
Axle ratio: 4:30
Tires: 38x15.50Rx17
Highway Fuel Economy Empty (7200 lb):
12 mpg @ 56 mph
10 mpg @ 72 mph
9 mpg @ 76 mph
Highway Fuel Economy Loaded (truck/trailer/jeep 13,800 lb):
8 mpg @ 62 mph
6 mpg @ 72 mph
SUV:
2011 Jeep Wrangler Unlimited
Drive: 4x4
Engine: 3.8L v6 minivan, 2.5" Flowmaster cat-back exhaust
Trans: 4-speed auto
Axle ratio: 4:10
Tires: 37x12.50Rx17
Highway Fuel Economy Empty (5500 lb):
18 mpg @ 56 mph
15 mpg @ 72 mph
12 mpg @ 76 mph
Highway Fuel Economy Loaded (jeep/trailer/RZR 7,800 lb):
13 mpg @ 62 mph
11 mpg @ 72 mph
Smiley is offline   Reply With Quote
Old July 7th, 2011, 11:14 AM   #35
kickstand
circling the drain
kickstand's Avatar
Just did 1,000 miles this weekend, went to snowshoe, west virginia. 75 mph in michigan, 60-65 in ohio, some stop and go, 65 or 70 mph in west virginia, some 55, and back. Mountains ate up some fuel mileage, but for the entire trip I averaged 17 mpg. 18 hours total trip time.
56 mph average, including fuel and food stops. Probably closer to a 65 mph overall driving average.
Old July 7th, 2011, 08:51 PM   #36
mudrunner456
mudrunner456's Avatar
Truck: 1997 f-350 crew cab long box
engine: 7.3 powerstroke
drive: 4wd
trans: auto
mileage: 168,000
tires: 315-75-r17 bfg all terrains
mods: stock downtube no cat 4 inch to 6 inch dual stacks
k&n cold air intake
superchips tuners always on tow safe mode
Best fuel economy empty 7800 lbs: 17.5 mpg @65
Best fuel economy loaded 13,800: 13.5 mpg @ 65
looking at everyone elses numbers i feel i should be getting alittle better empty? maybe the big tires?
mudrunner456 is offline   Reply With Quote
Old July 7th, 2011, 08:58 PM   #37
ScOoTeR
hoo dat. wat.
ScOoTeR's Avatar
The stock downpipe is pretty restrictive, and those tires are pretty big to turn.
@clarkstoncracker
Old July 8th, 2011, 09:51 AM   #38
mudrunner456
Yea i need tires soon so i was thinking about downsizing a bit.
Old July 8th, 2011, 10:24 AM   #39
ron86toy
R&V Ranger
ron86toy's Avatar
Send a message via Yahoo to ron86toy
Truck: 2001 Ford Excursion
drive: 4wd 3.73
trans: auto
mileage: 216,000
tires: 265/65/18 bfg all terrains
mods: 4" turbo back
intake
edge programmer
Best fuel economy empty 7800 lbs: 21mpg @68
Best fuel economy loaded 14,700: 15 mpg @68
ron86toy is offline   Reply With Quote
Old July 9th, 2011, 02:13 AM   #40
lauriat
lauriat's Avatar
X2
But roughly I was getting 13.5 empty with stock 265/70/17's, 12.5 with a leveling kit and 285/70/17 duratracs (empty) 7.5 with my four-spot enclosed with 4 sleds in it, 11 empty after the 7" lift and 325/65/18 toyos.
The truck is a 2010 2500hd crew cab, 3.73's 6 speed auto, 4x4, 6.0 vortec.
lauriat is offline   Reply With Quote
Page generated in 0.41765 seconds with 84 queries
