Small Block Stroker - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 29th, 2011, 01:32 PM   #1
swamprat
Eat, Sleep, Breathe Camo
swamprat's Avatar
Default Small Block Stroker
I know the 302 stroked out is a 347 but what is a 351 stroked out? I have a 93 Ranger that I am going to put a small block in maybe next year. What are the advantages and disavantages to the stock 351W vs. a stroked out one? Is this something I should do for this project or should I just run a stock small block?
swamprat is offline   Reply With Quote
Old June 29th, 2011, 01:40 PM   #2
masterbeatty
masterbeatty's Avatar
well the 351 block is stronger than the 302. 302 is a little smaller but im pretty sure the 351 will fit into the ranger. i know my 351 bronco moves along purdy good. the 302 in my mustang also moves along purdy good. alot of weight in the bronco and it still moves for being stock. and 351s can be stroked and bored to 357 393 408 427 i am sure there are more but thats what i know of.
Old June 29th, 2011, 02:11 PM   #3
swamprat
swamprat's Avatar
I am about dead set on getting a 351... I just donk know yet if I want to stroke it...
Old June 29th, 2011, 02:28 PM   #4
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
First off if your gonna stroke it your gonna wanna bore it as well. Stroker engines take more block work as well, clearing the longer rod and such. You also have to set a price on how much you wanna spend on the engine first then go from there. Also built right a 351 can make good power w/o a upgrade!
Old June 29th, 2011, 03:17 PM   #5
Bones
Bones's Avatar
for the best combination of HP and TQ, look into a 393 or 408 stroker kit. Almost all stroker kits are close to the same price, indepentant of cubic inches. For example a forged 396 kit and a forged 427 kit aren't far off in price. Don't get sucked into thinking the more displacement the better. There is a ton of research out there, here is a descent start
http://www.alternativeauto.com/water..._strokers.html
A 408 is planned for my buggy.
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old June 29th, 2011, 03:33 PM   #6
frdboy
frdboy's Avatar
X2
I have done both 408 (4" stroke 4.030 bore) and 418's (4.100 stroke), I like the 4" stroke better. I do not like the budget 393 kits as most still use the big 351W (2.3") rod as opposed to the better 2.1" rods in the better kits.
Very little if any block work is needed to fit the 4" deal.
Unless you are planning on over 600 HP or a power adder I would use a good (scat, Eagle) cast crank and some good I-beams, a forged crank is a waste of $$ at that level. Spend the money on good heads and valvetrain, thats where it's needed. 302 parts (heads) on a 408W is gonna make 302 power.
The difference in money is very little if you are comparing it to a stock rebuild that includes turning the crank, adding good bolts to the rods, good pistons and balancing.
Old June 30th, 2011, 02:17 AM   #7
swamprat
swamprat's Avatar
I would be happy with like 450 hp cause in my ranger that would be more then enough. Thanks guys for the advice.
Page generated in 0.31890 seconds with 44 queries
