2002 Chevy Silverado Step Side (Lifted) (Custom) - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 29th, 2011, 08:09 AM   #1
white1500
Default 2002 Chevy Silverado Step Side (Lifted) (Custom)
This is an excellent driving / running truck. I am the 2nd owner, I have owned the truck for 1 year. I bought it off of the original owner! The Truck has 67,000 original miles and counting (My daily driver) 4 speed Auto Trans, Push button 4x4, Cruise, Tilt, A/C, Overhead Console, Power Window's, Lock's, & Mirror's. Both front seat's are Captain's Chair's W/full Power, Lumbar, & fold down Arm Rest's. The center Console will fold up to create a 3rd seat or leave it down for additional storage / arm rest. The Truck was just completely painted! Jamb's, Inside edge's of door's & tailgate, etc. Everything work's as it should & all of the recommended / standard maintenance is up to date. I am extremely meticulous with maintenance and I keep the truck very clean at all time's. The truck is obviously not stock, but the mod's are tasteful and they serve a purpose. Currently upon my last fill up with gas, the truck is getting 15.8 mile's per gallon (City) I do not drive much freeway so I could not tell you what it get's there. I have never taken this truck off-road / 4 wheeling, only used it to get my other toy's out to the riding area. I could not afford to break something on it since it is my daily driver...The only reason that I am selling this truck is because of my expanding family and the need for a larger vehicle.
MAINTENANCE SCHEDULE________________________________
1. Oil & Filter change every 3000 Mile's (Valvoline Max Life)
2. Transmission Service & Filter @ 47K (Royal Purple Synthetic)
3. Transfer Case Flush & Fill @ 47K (Royal Purple Synthetic)
4. Front & Rear Differential Service @ 46K (Royal Purple Synthetic)
5. Cooling System Flush & Fill @ 47K
6. Air Filter & Tire Rotation completed every other Oil Change
AFTERMARKET PART'S AND ACCESSORIES________________________
1. 6" Suspension Lift W/Front Traction Bar's (Full Traction)
2. 5" Soft Ride Progressive Rear Leaf Spring's (Skyjacker)
3. 2" Rear Lift Block's & 2 Degree Axle Shim's (Pro-Comp)
4. Rear Ladder / Traction Bar's (Pro-Comp)
5. Front Skid Plate's (Full Traction)
6. Front & Rear Bump Stop's (Full Traction)
7. Front & Rear U-Joint's, W/Heavy Duty Needle Bearing's @ 60K (Moog)
8. Heavy Duty Upper Ball Joint's @ 60K (Moog)
9. Front Hub's / Bearing's @ 57K (Timkin)
10. Pitman & Idler Arm Support System (not installed yet) (Cognito Motorsport's)
11. 4.88 Ring Gear's Front & Rear (Superior)
12. Rear Differential Locker / Posi (Eaton)
13. 32 Spline Rear Axle's (Superior)
14. A/C Delco Rapid Fire Spark Plugs
15. High Performance Plug Wire's (Granitelli)
16. Cold Air Intake (Spectre / K&N)
17. Throttle Body Spacer (AFE)
18. Cat Back Exhaust (Magnaflow)
19. 17x8.5 Wheel's w/3 year transferable warranty (Moto Metal)
20. 35x12.50x17 Tire's w/3 year transferable warranty (General)
21. Stereo Head Unit W/ 7" Touch Screen Monitor / DVD Player (Kenwood Excellon kvc911-dvd)
22. Door Speaker's = Kenwood Excellon 6.5" 2way & Rockford Fosgate 3.5" Coaxal 2way
23. Subwoofer = 10" Kicker Square L7 Solobaric in a ported box behind passenger seat
24. Amplifier's = Rockford Fosgate, 1500 watt 2 channel & 900 watt 2 channel. Both are mounted on an Amp Rack behind the driver's seat. Everything has new professionally ran wiring and power / ground distribution block's.
25. Battery (Optima Red Top)
26. Bedliner (GM Factory)
27. Tonneau Cover (Access Vanish)
28. Auto Meter Steering Column Pod & Phantom Vacuum Gauge.
29. Diablo Predator Power Programmer
30. Collapsible / expandable Steering Shaft (Borgenson)
Asking $14,400 (o.b.o.)
John
248-Eight Nine Five-7700 (call or text) Please leave a message. Your call will be promptly returned...
248-698-8650 (Auto-Tech Collision, between 8 & 6)
ID:	80817   Click image for larger version
ID:	80818   Click image for larger version
ID:	80819   Click image for larger version
ID:	80820   Click image for larger version
white1500 is offline   Reply With Quote
Tags
chevrolet, custom, lifted 4x4, silverado, step side
Page generated in 0.21555 seconds with 27 queries
