any foxbody people here? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 28th, 2011, 12:06 AM   #1
masterbeatty
masterbeatty's Avatar
Default any foxbody people here?
looking at possibly doing a 351 swap and went to a couple sites and already got banned from one cause of some wlb. just looking for info and possibly some specs.
Old June 28th, 2011, 12:32 AM   #2
stuckinthemud
stuckinthemud's Avatar
whatcha need to know pm me i know alot with fox bodies just gettin done building one myself with a built 306
stuckinthemud is offline   Reply With Quote
Old June 28th, 2011, 12:34 AM   #3
V8Mustang1967
V8Mustang1967's Avatar
I could toss you some useful information i suppose as well. www.buckeyestangs.com is a good site to get some info from as well.
V8Mustang1967 is offline   Reply With Quote
Old June 28th, 2011, 09:10 AM   #4
kickstand
circling the drain
kickstand's Avatar
my fox body
Old June 28th, 2011, 09:31 AM   #5
masterbeatty
dont temp me. i finally have a good running 20mpg car 40 bucks fills it and she scoots along. if i start with that crap ill be introuble. haha but i like the way you think
Old June 28th, 2011, 09:34 AM   #6
Jmccormick
are you trying to stick with EFI?
http://mustangforums.com/forum/351-m...onversion.html
Jmccormick is offline   Reply With Quote
Old June 28th, 2011, 09:45 AM   #7
masterbeatty
no its an 83 and already has an 01 explorer roller motor with gt40p heads shortys edelbrock intake and holly street avenger 3.73s t-5
Old June 28th, 2011, 11:14 AM   #8
Toivo
Feel lucky?
Toivo's Avatar
So it already has a bunch of goodies on it.
Why the hell do you want to put a 351 in?
Old June 28th, 2011, 11:39 AM   #9
Jmccormick
simple, stock bottom end 302's are like glass. the block is also like glass when a lot of power it made.
windsor has 50 more cubes, and a stronger block.
Old June 28th, 2011, 11:53 AM   #10
masterbeatty
more torque and power stock for stock and the 351 can make 400rwh easy from what i understand.
Old June 28th, 2011, 11:54 AM   #11
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
Good to see the sites. I would like to build a fox body in a year or 2. I am struggling with using a 351, or a 3rd gen motor? I used to hate when people did the chevy to ford conversion, but 5.3 and 6.ohs are sooo easy to convert.
RIP FULLSIZE4LIFE
Old June 28th, 2011, 11:56 AM   #12
masterbeatty
please stick 351 or 302 haha i also hate it when i see chevy to ford conversions
Old June 28th, 2011, 10:02 PM   #13
Jmccormick
can't beat the LSx swap in a notch.
pick up a 5.3 out of a truck for $800, stick a cam and long tubes on it with a stand alone you have yourself a budget friendly 10 second car.
Old June 28th, 2011, 10:05 PM   #14
nick_n_ii
nick_n_ii's Avatar
Send a message via Yahoo to nick_n_ii
I much rather like the Fox Body's with the Turbo Coupe 2.3 Turbo in them.
Gas mileage and blow the doors off most V8's...
nick_n_ii is offline   Reply With Quote
Old June 28th, 2011, 10:07 PM   #15
masterbeatty
im gettn 20s out of myne right now
Old June 28th, 2011, 10:07 PM   #16
frdboy
frdboy's Avatar
X2
Very easy to make killer power with a stroked 351W.
Here is my foxbody.
Old June 28th, 2011, 10:26 PM   #17
masterbeatty
so i like people here far more than the mustang sites. there cocky and arrogant to no end.
here is what i have to work with.
96 roller 351
gt40p heads
ill get a cam and springs, most likely do some cleanup on the heads and would like to do it over the winter. i dont have the coin to drop on aluminum heads plain and simple. and i wont. maby down the road or if i find a good deal yes. but for now gt40ps or e7s what would be my best option
Old June 28th, 2011, 10:34 PM   #18
don4life
don4life's Avatar
i have read and seen many chevy ford small block build off's and myself preferring chevy a 351 will beat a 350 build to build every time, they have a taller block, longer rod and comparable head selection, my only worry would be the gt40p heads and if they are gonna be to high on compression and have a big enough runner to feed a built 351(they may i havn't studied ford tech in a while)
GL
don4life is offline   Reply With Quote
Old June 28th, 2011, 10:36 PM   #19
masterbeatty
i dont plan on a stroker or anything like that right now. really its a budget. i want to get the suspension, 5 lug conversion, wheels and tires and the 351 in this winter.
Old June 28th, 2011, 11:10 PM   #20
stuckinthemud
im thinking just port the 351 heads or even find an older set of the windsor heads they are pretty cheap to find older stock ones i have a set of 71 302 heads that have been hogged out that would most likely flow more then the gt40 heads ill let them go for reasonable price if your interested
Page generated in 0.35449 seconds with 83 queries
