DANA 60 lockers - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 5th, 2011, 07:48 PM   #21
dougstephvoor
Supreme Chancelor!
dougstephvoor's Avatar
Do you guy's with solid lock front, welded or spools, break u-joints and stub axles on d60's? My D44 breaks stub axles and u=joints frequently when trying to turn sharp with the locker engaged. Is the 60 heavey enough where it does not matter?
dougstephvoor is offline   Reply With Quote
Old September 5th, 2011, 08:06 PM   #22
When you install the front shafts are lining them up left to right to minimize binding?
Old September 5th, 2011, 09:29 PM   #23
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
Been running a welded front for 5 years and still on the first set of u-joints and shafts. Im not real easy on it
Old September 5th, 2011, 09:32 PM   #24
Shotgun
I only wheel with boats.
Shotgun's Avatar
I could tell when I helped take the front end apart during the motor swap. The shit was rusted in!
Old September 14th, 2011, 12:04 PM   #25
PatriotWheeler
Default Spend the extra $50 bucks!
For ~$600 you can get the real deal from Summit Racing. The Yukon is a "generic" version of the Detroit. Looks the same, and the parts most likely will fit together (wouldn't call them interchangeable!). But, it isn't an engineered product and is made by an aftermarket company, not an OEM supplier like the Eaton Detroit Locker product. Been there. You won't regret the extra couple of bucks. All of the light duty versions (Spartan, etc) are for light duty use. If you're running a 60 model, I gotta assume you either have a heavy truck, very large tires, or substancial driveline torque multiplication to the axle.
...my experienced 2 cents.
PatriotWheeler is offline   Reply With Quote
Old October 20th, 2011, 12:04 PM   #26
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I got a Spartan, we will see how it holds up, I am sure i will test it out good.
Old October 20th, 2011, 12:22 PM   #27
Freak
Wheelin the HD
Freak's Avatar
I like my spool, but then again I'm still wheeling the jackstands.
Old December 4th, 2011, 02:52 PM   #28
bbrancheau
BLB CONCRETE
bbrancheau's Avatar
In about two months i will be doing the same.. Update on how it dose
bbrancheau is offline   Reply With Quote
Old December 4th, 2011, 03:32 PM   #29
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
Could anyone explain this further?
Old December 4th, 2011, 04:05 PM   #30
Freak
Wheelin the HD
Freak's Avatar
It's called phaseing the shafts. Supposed to reduce bind. With a LSD or locker it won't work because the shafts can spin individually, but welded or spools they stay lined up. Esentully when you put the shafts in you make sure they are in the same orientation. Or is it 180 off?
Old December 4th, 2011, 05:01 PM   #31
wadey
┌∩┐(_)┌∩┐
wadey's Avatar
hmm Ill have to look it to that considering I have a spool. Thanks
Page generated in 0.28750 seconds with 56 queries
