F350,zf6 hard shifting when hot. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 26th, 2011, 12:31 PM   #1
219xj
219xj's Avatar
Default F350,zf6 hard shifting when hot.
i have a 1999 F350, 7.3, 6-Speed. ive been having problems with shifting after i drive awhile. i took a trip up to south bend last weekend and by the time i got home from about 3 hour round trip i was having problems gettng the truck in and out of gear at a stop, but when im driving it shifts normal.....ive been told its my clutch going out? or does it just need re-bled? is it getting to hot? i just chaged the fluid with mobil 1 full synthetic atf. that made a little difference on shifting from a stop. but when i get into it in the morning it shifts like thers no problem making me think its the clutch and not the trans. becaue syncros will cause the trans to shift poorly no matter the temperature.... also my petal is to the floor.. the trans and clutch was replaced around 80,000 miles ago...
this is my first time owning a manual truck and im not sure how to re-bead the system. so if anyone has any tips or advise please let me know
219xj is offline   Reply With Quote
Old June 26th, 2011, 05:09 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
sounds to me like you have a master or slave cylinder going bad. when you push the clutch to the floor is there resistance on the pedal the whole way or is it very easy to push till you get to the very bottom? another thing to verify the problem is to put it in 1st gear with the truck not running, hold the clutch to the floor and start it. if the truck tries to move then i would say the clutch is not being released all the way. either way this is probably a hydraulic problem.
Old June 26th, 2011, 05:25 PM   #3
219xj
219xj's Avatar
Kodiak450r thanks! When I push it to the floor it feels normal all the way Down. And when I put it in gear and start it, It stays in place. I'll replace the master and slave cyl and see what happens.
Old June 26th, 2011, 05:54 PM   #4
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
what exactly is happening when you try and put it in gear? grinds or just won't go in unless you force it? this could also be sign of a bad pilot bearing if it wasn't replaced when the clutch was put in.
Old June 26th, 2011, 08:14 PM   #5
oilburner350
oilburner350's Avatar
Dual mass flywheels can also do funny things. The hydraulic set up would be my first suspect.
oilburner350 is offline   Reply With Quote
Old June 26th, 2011, 08:32 PM   #6
Toivo
Feel lucky?
Toivo's Avatar
Also, there is a plastic bushing that goes on the end of the clutch linkage on the pedal end. If that bushing is gone, you are losing some travel, and it can lead to wear elsewhere. About $8 at your dealer for the part.
Slave and master, I'll agree. Pull the seal lip out and check to see if there is fluid in the bore. If there is, there's your issue.
A bad/gone pilot bearing can also cause this problem. I had a cracked clutch hub disc that warped when the clutch was pushed in, and that was my issue. The master and slave were good, the clutch disc and the pilot bearing were bad, causing my issue. Check things out before you throw money at it. Truck parts ain't cheap
Old June 26th, 2011, 08:33 PM   #7
Toivo
Feel lucky?
Toivo's Avatar
S-Duty's have single mass flywheels.
Old June 26th, 2011, 09:12 PM   #8
oilburner350
Yup, that's right, dual mass ended in '97. The supery dutys like to throw the hub springs as well.
Old June 27th, 2011, 12:14 AM   #9
Toivo
Feel lucky?
Toivo's Avatar
Yup, which is a direct link to shitty shifting since it usually takes the pilot bearing out too.
Old July 4th, 2011, 12:20 PM   #10
219xj
219xj's Avatar
i checked the bushing on the master cyl and it was gone...made up a new one on the lathe and put her back together.. workes like a champ.. thanks for all the great info guys
Old July 4th, 2011, 09:01 PM   #11
Toivo
Feel lucky?
Toivo's Avatar
Do you want to make me one?
I keep crushing the janky plastic ones.
I'll pay a nominal fee of course.
Page generated in 0.35178 seconds with 56 queries
