turbo 350 help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 14th, 2006, 06:28 PM   #1
biggs-cj
biggs-cj's Avatar
Default turbo 350 help
allright need some info ,,,my 350 chevy trans,,,in my jeep lost all forward gears at the pig gig,all i have now is reverse........it was a new trans intell i broke the case in half in grand mans old tank trap.....had someone change it all over to a good case,,,,,,i havent put over 20miles on it,,,,,,,now i loose 1st 2nd and drive............what could it be ,,,,,,besides the guy keep my good trans and gave me a old ready to go trans??????????
biggs-cj is offline   Reply With Quote
Old September 14th, 2006, 07:26 PM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
since your close by to Chelsea I have buddy who works at the chevy dealer who does trans work on the side. he can hook you up with a case if thats all you need. he's not the cheapest but he knows his shit.
Yetti
Old September 14th, 2006, 09:09 PM   #3
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
you smoked the foward clutch out of it.
Old September 15th, 2006, 06:57 AM   #4
biggs-cj
biggs-cj's Avatar
thanks the case is fine,,,,,,,,it was swaped with a good case 2ys ago when i broke it,,,,,,just trying to figure out what happened to make forward gear go?
Old September 15th, 2006, 06:58 AM   #5
Yetti
Yetti's Avatar
I guess I was tired when I read it last night. yea its forward clutchs.
Yetti
Old September 15th, 2006, 07:01 AM   #6
biggs-cj
biggs-cj's Avatar
should all new clutches go like that with less then 20miles on them......thanks for the info,,,,,,,,,i need to talk with the guy ,that put it all together in the new case......i still think he screwed me and gave me a old trans then took all my new parts........just hard to prove it
Old September 15th, 2006, 07:04 AM   #7
biggs-cj
biggs-cj's Avatar
thanks again for the help,,,,,,,,going to do some ranting to the guy about this happing.......
Old September 15th, 2006, 08:38 AM   #8
KILLER"B"468
Yankabilly
it only takes 20 miles to smoke them, couple things could of happend.
screwed you and put in junk.... which happens quite often
if he went thru and checked everything out, knicked a seal putting it back together. Or took springs out of the retainer thinking it will make it shift harder (it won't)
putting the pump in broke a cast ring on the pump.
Old September 21st, 2006, 05:17 AM   #9
biggs-cj
biggs-cj's Avatar
so how hard is it to take a 2 wheel trans and put the out putshaft from my 4 wheel trans in it???
Old September 21st, 2006, 05:49 AM   #10
KILLER"B"468
Yankabilly
Pull the pump and all the guts down to the output shaft. install in reverse order with 4x4 outputshaft. I would buy a manual for some tips to remove and install the stuff.
Page generated in 0.28332 seconds with 53 queries
