Chevy 307 TBI - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 21st, 2011, 12:19 PM   #1
Bigcj8065
Default Chevy 307 TBI
Early 1970s recently rebuilt small block chevy v8 307cid .030 over.
Rebuilt approx 2 years ago and not use very often, runs great and sounds great.
Rebuild included - new crank, all bearings, gaskets, rings, machine work, timing set, high volume oil pump, Edelbrock EPS intake,
Edelbrock TBI Cam/Lifter kit PN 3702.
TBI fuel injection with modified factory harness/computer/sensors/throttle body included.
Carter TBI fuel pump also included, if you want I will include slosh tank and second pump to feed it.
I am going away from TBI, so basically everything it takes to run this motor is included. I will keep the accessories - pullies, alternator, power steering. Also headers.
It is in a jeep now and you can come hear/see it run. If you want it leave a deposit (minimum $200) and I will pull it all apart for you.
Let me know if you want additional details or if there are questions. I am open to negotiation.$880 obo.
Bigcj8065 is offline   Reply With Quote
Old June 21st, 2011, 01:37 PM   #2
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
So is it a 305 @ 0.030 over or a 307 @ 0.030 over?
Old June 21st, 2011, 01:52 PM   #3
I suck cocks. Lots of them.
locally famous
early 70's=307
Old June 21st, 2011, 02:04 PM   #4
BigBlockBlazer
Axle breakin' 101
I though the 307's were pretty rare, or was it the 302?
Old June 21st, 2011, 06:46 PM   #5
robo-3
02 tj
robo-3's Avatar
302 rare 307 lots!
robo-3 is offline   Reply With Quote
Old June 21st, 2011, 07:55 PM   #6
Bigcj8065
Its a 307 that is .030 over.
Old June 22nd, 2011, 08:08 PM   #7
Bigcj8065
Anyone? Make an offer....
Old June 22nd, 2011, 08:43 PM   #8
stroker00s10
Odd Man out with a S10
stroker00s10's Avatar
txt me 810 410 6600 i am interested in tbi setup mainly for my sbc s10. are you going carb and sbc cause I have all new for sbc Holley 650 vac 2nd edelebrock eps performer manifold carter hi flow mech fuel pump
stroker00s10 is offline   Reply With Quote
Old June 23rd, 2011, 06:43 PM   #9
Bigcj8065
Stroker00s10 - let me know if you are interested....?
Will breakup engine and TBI setup. Also have a couple extra factory TBI intakes, a TBI distributor, set of factory heads (need rebuild) from 1991 350 suburban, throttle body base and some other random parts. If any ones interested make an offer...
Old June 30th, 2011, 12:24 PM   #10
Bigcj8065
Still got - will be out of truck soon and will not be able to hear run... make an offer....
Tags
307, chevy, jeep, sbc, tbi
Page generated in 0.21233 seconds with 54 queries
