d44 cast wedges - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 21st, 2011, 11:16 AM   #1
2fst4you
2fst4you's Avatar
Default d44 cast wedges
I'm looking to buy a d44 that is set up for radius arms. I want to make it a 3 link when it goes in my jeep. It has cast wedges so what can I do about this?
Old June 21st, 2011, 11:18 AM   #2
94jimmyjr
94jimmyjr's Avatar
plasma cut them off...
94jimmyjr is offline   Reply With Quote
Old June 21st, 2011, 11:26 AM   #3
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Use the Ford radius arms and a track bar.....
Use the Ford radius arms and convert the other end to a flex joint....
Ignore them and weld your own brackets on......
Old June 21st, 2011, 11:33 AM   #4
2fst4you
2fst4you's Avatar
Would I be able to weld to the cast? Can a plasma cut through a wedge that thick.....
Old June 21st, 2011, 11:38 AM   #5
bigbchevy
missmrgreenagain
bigbchevy's Avatar
PEOPLE can weld to cast it just takes more to do it
H.o.r.e
Old June 21st, 2011, 11:43 AM   #6
What should you do? Pay attention to the advice you got in the other thread you just started.
You wonder why people pick on you. Well, here's a perfect example. You start a thread wondering what you should do. NO ONE GAVE YOU D44 ADVICE FOR YOUR FRONT END. But, you're ready to buy one anyway. Why did you bother to ask if your mind was already made up? After all, you just started the other thread this morning at 3:37am. There's no doubt that you already had this one lined up and were just looking for reassurance that you should buy it. No one did but you want to anyway.
Here's my advice. Don't ask questions. Just do whatever you want.
Old June 21st, 2011, 12:11 PM   #7
Wrong, there's no tube under them.
Old June 21st, 2011, 12:11 PM   #8
2fst4you
2fst4you's Avatar
I want to buy this d44. I did listen to your advice and I want a d60 but this 44 is already built and a sixty would be alot more money then I have. The d44 will fit my needs so I will get it and upgrade to a one ton axle in the future if needed. Whiterhino you said for good shafts in a d44 it would be $1000 if this axle wasnt already built if get a d60 but it is. The ? about the cast wedges just came up because my buddy gave me some insight about. If people can weld to cast or I can cut these wedges off and run a 3 link then this axle will work. I appreciate everyones help but for my needs this is a perfect axle. You guys answered my ?s and now im making a decision. Thanks
Old June 21st, 2011, 12:14 PM   #9
Two main options with those axles:
1) Use the Ford Radius arms
2) Have the axle retubed.
I have a few pairs of those axles, will be changing it to a passenger side diff and retubing the drivers side.
Old June 21st, 2011, 12:16 PM   #10
2fst4you
2fst4you's Avatar
How will the radius arms compare to a 3 link? How do I got about retubing....
Old June 21st, 2011, 12:28 PM   #11
OK, I hear your arguement. Just an FYI so you don't think I'm picking on you, I went the exact same route and spent the money on alloy shafts. Then I witnessed a D44 chromo stub shaft break in a parking lot on a log with a 37" tire. That's when I realized going to a 60 was the only way to go.
RE your question, radius arms work pretty good but won't give you the flex of a fully linked axle. If you're not sure what they are, look at any full size Bronco or F150 from the late 70's to 80's. This would be by far the cheapest way to go. Take Hag gar up on his offer.
Old June 21st, 2011, 12:39 PM   #12
2fst4you
2fst4you's Avatar
Thanks! I just feel like $700 for an axle that has everything I want is a steal and something I cant pass up on....but i could be wrong?
Idk how to retube an axle.....this easier or would welding to the cast be? I want a 3 link!
I would but I have an axle in mind
Built dana 44 and matching 8.8 full width - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 21st, 2011, 01:27 PM   #13
thrill20
thrill20's Avatar
http://www.greatlakes4x4.com/showthread.php?t=209013
Bolt on to factory wedges.... and the best flex you can get out of radius arms.
google james duff arms, or cage radius ams. same design, but cage went out of business.
http://www.fullsizebronco.com/forum/showpost.php?p=1888699&postcount=5
thrill20 is offline   Reply With Quote
Old June 21st, 2011, 02:22 PM   #14
Oh, I'm not making any offers..hehehe. I'm doing that for my scrambler. But I know how I wheel, and the D44 works for what I do.
If you get chromo axles, get good ones, not the cheap yukon ones that are weak as stock that a certain someone broke in the parking lot on a log. :hehe:
Old June 21st, 2011, 02:24 PM   #15
Plato2k5
In Da Faaaaaace!!!
Plato2k5's Avatar
Haggar, I had the wedges on my D44 and I cut them off. There was a tube under it. Does it depend on the year?
Old June 21st, 2011, 02:35 PM   #16
Dylan
Dylan's Avatar
the cast wedges are the tubes them selves. The stamped wedges are welded to the tube and can be cut off. I don't know the year difference but you can tell just by looking at them.
Old June 21st, 2011, 03:27 PM   #17
2fst4you
2fst4you's Avatar
Id like to run a 3 link! How do I modify that axle for that?
Old June 21st, 2011, 05:45 PM   #18
powerranger33
powerranger33's Avatar
Look for a d44 that is outta '77 or earlier because they have welded on wedges
powerranger33 is offline   Reply With Quote
Old June 21st, 2011, 07:25 PM   #19
2fst4you
2fst4you's Avatar
I decided to just wait until I have money to do a d60. I need a new trans in my jeep and want to save for another car before I do such big swap
Old June 21st, 2011, 08:16 PM   #20
Yes, and the vehicle.
Here's a cutaway from the cast wedges:
The 78-79 F150s (most of them) and Broncos they have cast wedges.
77 and earliest usually have welded wedges. F250s with D44s fronts (some had 60s) had leaf springs, so no wedges to get rid of, just spring perches. Certain club/crew cab F150s also had leaf spring fronts.
Places like DTS can retube an axle for a couple hundred bucks. Or you can do it yourself if you have a welder, plastma, press, and lathe. Conveniently, I do.
Page generated in 0.48675 seconds with 84 queries
