97 ram 2500 brake rotor/ wheel berring help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 17th, 2011, 09:08 PM   #1
fabguy01
hammer down grabbin gears
fabguy01's Avatar
Default 97 ram 2500 brake rotor/ wheel berring help
ok i know how this sounds "like im an idiot", but i am doing a brake job on my 97 2500 ram with a dana 60 front and i can't get the wheel berring/brake rotor to come off. i have removed the caliper, axle nut, and the 4 bolts that attach the wheel berring to the knuckle. am i missing somthing???? And yes i have tried th BFH. thanks
fabguy01 is offline   Reply With Quote
Old June 17th, 2011, 09:36 PM   #2
DodgeDude99
you need to try a bigger BFH, rust holds like a bitch with the unit bearings.
DodgeDude99 is offline   Reply With Quote
Old June 17th, 2011, 09:37 PM   #3
87mopar
Web Wheeler :(
87mopar's Avatar
this may sound stupid but is there 2 nuts and a lock ring? my older dodge had this. I am not sure if it is similar
my only help :
http://bronco.zenseeker.net/Images/Dana60.GIF
"Insert Comedic and or ego boosting quote questioning another members sexual orientation here"
http://www.greatlakes4x4.com/imageho...60bd7ea6d9.gif
87mopar is offline   Reply With Quote
Old June 17th, 2011, 09:40 PM   #4
thrca
UberGeek
thrca's Avatar
X2, my older dodge d60 has a pair of 2 13/16 nuts inside the hub.
Sent from my DROID PRO using Tapatalk
thrca is offline   Reply With Quote
Old June 18th, 2011, 08:18 PM   #5
fabguy01
fabguy01's Avatar
got it . had to screw in the 4 bolts that hold the berring to the knuckle like half way then use the air hammer on them to pop the unit berring out
Old June 18th, 2011, 08:19 PM   #6
fabguy01
fabguy01's Avatar
my only help :
nope this has unit berrings thanks though
Old June 18th, 2011, 08:51 PM   #7
87mopar
Web Wheeler :(
87mopar's Avatar
glad you got it
Page generated in 0.33440 seconds with 44 queries
