Ford Rules 95 ranger 1 ton swap yada yada yada - Page 5 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old May 20th, 2012, 09:18 PM   #81
bigbchevy
missmrgreenagain
bigbchevy's Avatar
nice work man
H.o.r.e
Old May 21st, 2012, 04:52 AM   #82
Ford rules
Ford rules's Avatar
Originally Posted by Kyle M. View Post
What are you doing for steering? Did you cut the frame at the box?
And one last question, what does you bump stop hit on? I am putting the same style bump on mine and I was looking at using the track bar mount.
I cut the frame just after the box do its still stock location.
There is a bump pad right in the center of the tube it lands on I'll get some more pics of it tonight.
Originally Posted by bigbchevy View Post
nice work man
Thanks a lot!!!
Old June 17th, 2012, 05:39 PM   #83
Ford rules
Ford rules's Avatar
About time for a update I geuss!!
Been real busy with work lately, also burned 2 weekends up with a good friend that was on military leave but well worth it to hang out with him.
Picked up a used hoist its a benwil 8000lb.
So this weekend I got the front frame all tacked together and got the radiator and inter cooler mounted up. Just gotta drill a few holes and mount the winch.
Onto the pics.
AF ratio
Bosch 044
Motor basically done
Testing the hoist!!
Winch is nice and tight
A buddy had fun with a label maker
Thinking of running my crossover pipe through here any opinions it is Linda close to the fans and the accessories
Old June 17th, 2012, 06:27 PM   #84
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
I think I would run it under to keeps engines bay temps down.
Old June 17th, 2012, 06:53 PM   #85
Ford rules
Ford rules's Avatar
Thats kinda what i was thinking also, Gonna be real tricky to get it underneith though.
Old June 17th, 2012, 07:13 PM   #86
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Think you could run a passenger side manifold on the drivers side, flipped front to rear. Then go down and under the crank pulley. Just not sure on space with the oil filter/relocater.
Old June 17th, 2012, 07:22 PM   #87
Ford rules
Ford rules's Avatar
I may be able to but im not sure, gonna have to tinker with it more this week ive only got about 2'' of room from the head to the stock steering shaft. I may build a skinnier steering shaft to give me a little more room. Ive gotta try and keep it away from the lower coolant hose also.
Old July 1st, 2012, 06:17 PM   #88
Ford rules
Ford rules's Avatar
Well got a little done this weekend, rebuilt the front frame again gonna run the radiator in the back. So winch is mounted up front and the inter cooler is as well. Mounted the rear fenders so I can mount the radiator off them.
Few pics
Old July 1st, 2012, 06:32 PM   #89
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Think I may actually make it out to see this in the next couple weeks. I have some time off work. Looks bad ass as usual. Keep it up!
Old July 1st, 2012, 06:35 PM   #90
Ford rules
Ford rules's Avatar
Sounds like a plan, I still gotta pull those heads off for ya!!
Old July 1st, 2012, 06:42 PM   #91
Kyle M.
MetroFab Customs
Kyle M.'s Avatar
Well, I'm glad you haven't been waiting for me....lol
Old July 1st, 2012, 06:43 PM   #92
Ford rules
Ford rules's Avatar
Lol na I'm not to worried about it!
Old July 2nd, 2012, 09:04 PM   #93
Ford rules
Ford rules's Avatar
I think im gonna try and get some tube this week and start a roll cage, basically just a bed cage for now to mount the radiator and tranny coolers. Finished up my bed sides tonight and started looking at tire mount ideas.
Was thinking something like this what do you guys think?
And was thinking of mounting these up here reverse and tail lights.
Old July 4th, 2012, 08:14 PM   #94
Ford rules
Ford rules's Avatar
Well worked on the truck all day and got almost nothing done... I geuss progress is progress though.
Started a simple bed cage with tube I had and I'm gonna get more tube Saturday morn. Radiator is almost mounted also.
Few pics
Old July 5th, 2012, 09:19 PM   #95
Ford rules
Ford rules's Avatar
Radiator is just about done and mounted.
The bolts sit in a hole and push the radiator down I'm gonna add a few little tabs too.
Little bracing for the lower mount plate.
Old July 24th, 2012, 08:02 PM   #96
Ford rules
Ford rules's Avatar
Okay so ive got a bit done i would say. Hot side is all done just needs finished welded. Before i weld everything together is there any other bungs i should weld into the downpipe i know i need my AFR bung and all the stock 02 sensors anything else?
Heres some pics.
I know the raer cage needs more triangulation just not sure what i wanna do yet any suggestions speak up please!!
Old July 24th, 2012, 08:17 PM   #97
sbcrichie
R&R Fabwerks
sbcrichie's Avatar
Originally Posted by Ford rules View Post
I like spare mounted in this position
sbcrichie is offline   Reply With Quote
Old July 24th, 2012, 08:32 PM   #98
Ford rules
Ford rules's Avatar
Ya im torn what i wanna do with it, i like the first way better also it will just be a little harder to do it that way.
Old July 24th, 2012, 08:38 PM   #99
bigbchevy
missmrgreenagain
bigbchevy's Avatar
done yet?
H.o.r.e
Old July 24th, 2012, 08:42 PM   #100
Ford rules
Ford rules's Avatar
Tomorrow maybe!!
Page generated in 0.52425 seconds with 83 queries
