Ford Rules 95 ranger 1 ton swap yada yada yada - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 17th, 2011, 07:49 PM   #1
Ford rules
Ford rules's Avatar
Default Ford Rules 95 ranger 1 ton swap yada yada yada
So ive been on the site for quite some time just lurking around and figured i would post up my build.
Heres it from the begining http://www.ranger-forums.com/showthread.php?t=70469
And here are the latest pics of the 60 all trussed up.
Few more pics.
Specs are 1995 ranger expo 302 stock besides from headers and intake, built 4R70W tranny, NP205, Tom woods rear driveshaft, hoopty front shaft, 14 bolt rear detroit locker 4.88 gears, d-60 king pin front 4.88 gears lunchbox locker, 63" chevys rear, 2.0x14 kings front, griffin radiator, derale tranny cooler, those are the big things listed any questions or comments lets hear em!
Old June 30th, 2011, 09:58 PM   #2
Ford rules
Ford rules's Avatar
Few more pics front clip is mounted back up its getting closer.
Buddy of mine had fun with the light covers.
Old June 30th, 2011, 10:17 PM   #3
knixon804
THE GENERAL
knixon804's Avatar
awesome man! good progress
2011 F-350, DELETED, INDUSTRIAL INJECTION SINGLE TURBO.... TOW PIG
UNDER CONSTRUCTION: LJ, STROKED LS, ONE TONS, 42" MTRS
JK 3" BDS LIFT, 33" DURATRACS, STEELIES, WARN
OFF ROAD ANONYMOUS- PROUD TO HAVE A PROBLEM (231) 383-5664
knixon804 is offline   Reply With Quote
Old June 30th, 2011, 10:33 PM   #4
jroberts#77
Fuck there goes the trans
jroberts#77's Avatar
i like it with with out the brush gard. but good start.
jroberts#77 is offline   Reply With Quote
Old July 1st, 2011, 06:16 AM   #5
disturbedsledneck
disturbedsledneck's Avatar
Should be a stout wheeler! Like!
disturbedsledneck is offline   Reply With Quote
Old July 1st, 2011, 07:10 AM   #6
Ford rules
Ford rules's Avatar
Ya brush guard has been gone for a while it will have tube style bumpers front and rear now.
Bib b chevy is installing my front gears im droppin the axle off to him and once he gets time he will get them done.
hoping to have it done soon!
Old July 1st, 2011, 07:16 AM   #7
curbdog17
Mini Van
curbdog17's Avatar
Nice build
Old July 1st, 2011, 08:06 AM   #8
deathbypsi
Brian R.
deathbypsi's Avatar
Sweet...in for updates.
Old July 3rd, 2011, 07:24 PM   #9
Ford rules
Ford rules's Avatar
Well havent done much to it its to hot out. over 100* in the barn...
did manage to get my guages mounted up and wired though.
Im having sme intermitten electrical problems that are really pissin me off... anyone good with electrical out there care to lend a hand lol?
Trying to upload pics but my comp is bein a massive turd.
Old July 4th, 2011, 09:55 PM   #10
Ford rules
Ford rules's Avatar
Well i think i have gotten my wiring issues figured out for the most part, which i am happy with.
I did notice that with the key on but truck not running the WOT ac cut out relay gets relativley warm as does the PCM relay is this normal?
Also painted my grill and a few trim piecec blk tistill gotta get the fenders and hood painted black to match the cab.
And got my coil over cross bar bent up and in place just need to make some flanges and weld it in tmrw morning should be done.
Should have my Corbeau 5 point comp. harness's tmrw also and i need to pick up a new cross shaft pin for the front 60 carrier.
Its getting closer!!!
Old July 10th, 2011, 10:34 PM   #11
Ford rules
Ford rules's Avatar
Gears are in thanks alot scott (bigbchevy)!!!
Got my limit straps mocked up today so the front end is complete and done other then final welding and gussets on everything then the major things are install 5 pt harness's make exhaust and engine cross member. hoping to have it done in august to go to the dunes for a shake down.
I so happy with how the trucks sitting right now!!!!!!!!
pics
Old July 11th, 2011, 08:08 PM   #12
chevotass
chevotass's Avatar
i pee'd in your axle tube thursday night at scotts. sawwy.
Old July 12th, 2011, 09:33 AM   #13
Ford rules
Ford rules's Avatar
Ha thats alright itll just mix in with the gear lube.
Old July 20th, 2011, 12:54 AM   #14
Ford rules
Ford rules's Avatar
So ive got the harness's installed and lots of little pidly shit done on the truck.
Pulled the t-case last night and went and got my 203 tonight to build my doubler. Hoping to have the doubler in by this weekend build some shifters for it then make a tranny mount and put the cab back on its getting alot closer then just gotta make the exhaust.
Old July 20th, 2011, 10:31 PM   #15
Ford rules
Ford rules's Avatar
Doubler is in!
Old July 21st, 2011, 10:10 PM   #16
Ford rules
Ford rules's Avatar
Doubler is in just gotta build my shifters.
Pics
Tranny coolers
Ohh shit bar
Frame plating
Old August 4th, 2011, 05:03 PM   #17
Ford rules
Ford rules's Avatar
Drove it to the house!
Old August 4th, 2011, 05:30 PM   #18
Ford rules
Ford rules's Avatar
Old August 5th, 2011, 07:20 PM   #19
Ford rules
Ford rules's Avatar
So the truck is missing under load and trying to accelerate.
I replace all plugs with NGK v-powers replaced a 02 sensor and added some fuel injector cleaner.
I replaced the coil packs just before the winter i geuss they could be bad anyone know how to check them?
Also probably gonna replace the fuel filter.
Old August 5th, 2011, 10:19 PM   #20
deathbypsi
Brian R.
deathbypsi's Avatar
Got any good pix of your shck hoops?
Page generated in 0.33597 seconds with 83 queries
