02 f250 powerstroke air conditioning - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 16th, 2011, 06:14 PM   #1
94transam25th
94transam25th's Avatar
Default 02 f250 powerstroke air conditioning
I have been having trouble with my air conditioning on my 02 f250. I filled it with freon and have checked the a/c clutch fuse but my air conditioning clutch will not engage.
Is there anything else i should look at? maybe a relay for the air conditioning?
thanks,
Brandon
94transam25th is offline   Reply With Quote
Old June 16th, 2011, 06:39 PM   #2
crossedup1
crossedup1's Avatar
power the clutch with a 12 DcV source and supply a ground and see if it locks up
crossedup1 is offline   Reply With Quote
Old June 17th, 2011, 11:31 AM   #3
davidkassie
davidkassie's Avatar
sounds silly, but, if you have any cylinder missfire codes, mainly po310-po318, ignition primary circuit problem, it will shut down a/c due to emissions, crazy, but burnt on this one before
davidkassie is offline   Reply With Quote
Old June 17th, 2011, 12:25 PM   #4
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
How did you charge it? Do you have the correct amount in the system?
Have you jumped the low pressure cycling switch?
If you have the correct charge in the system, I'd find an electrical diagram and trace it down from there. It's a pretty simple system electrically.
Page generated in 0.26148 seconds with 35 queries
