welded dana 30 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 16th, 2011, 05:37 PM   #1
91 k1500
Big Belly Customs
91 k1500's Avatar
Send a message via AIM to 91 k1500
Default welded dana 30
have an 89 xj with 4" lift and 31s, rear is already welded and thinkin about doing front. this is a trail rig only. No street use. Plan on making my own posi loc too so I can lock and un lock the right side axle shaft for making tight turns. Will it hold up? pros, cons?
91 k1500 is offline   Reply With Quote
Old June 16th, 2011, 06:54 PM   #2
I would carry spares. I've seen it hold up reasonably well in a CJ, but that Jeep was able to unlock the hubs on pavement.
Do the posilock and have spares.
Old June 16th, 2011, 07:47 PM   #3
2TrackJeeper
2TrackJeeper's Avatar
Put a TJ shaft in it. You can get a used one for $50 or less. It will hold up but its a bitch to turn.
2TrackJeeper is offline   Reply With Quote
Old June 16th, 2011, 11:38 PM   #4
yyj87
yyj87's Avatar
I ran this setup in my yj for a while, on 32s its one mean bitch to steer with tires aired down.
I broke two u-join in 6 months and I deserved both.
Fozzy lock it so that you can change back without tossing a carrier.
yyj87 is offline   Reply With Quote
Old June 16th, 2011, 11:39 PM   #5
HVYRTFT
Reed my teef
HVYRTFT's Avatar
fozzy
Old June 17th, 2011, 08:49 AM   #6
yyj87
yyj87's Avatar
I just pulled the fozzy out if the front of mine, if you want to make it up my way there yours.
Ill post up some pics tonight.
Old June 19th, 2011, 11:01 PM   #7
91 k1500
Big Belly Customs
91 k1500's Avatar
wish ya where alittle closer yyj87.... thanks for the replies fellas.... thinkin its gonna get the weld treatment in the next couple days.
Page generated in 0.23066 seconds with 44 queries
