01 Durango front driveshaft - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 15th, 2011, 08:27 PM   #1
Shotgun
I only wheel with boats.
Shotgun's Avatar
Default 01 Durango front driveshaft
are their any special tools/tricks needed to remove this POS shaft?
I am blessed to work on my brothers on Friday.
Old June 15th, 2011, 08:36 PM   #2
MiNi Beast
MiNi Beast's Avatar
yeah need a cutting torch and 5 gallons of gasoline.
Old June 15th, 2011, 08:38 PM   #3
Shotgun
Shotgun's Avatar
Thanks for the help.
Old June 15th, 2011, 08:51 PM   #4
MiNi Beast
MiNi Beast's Avatar
ok ok damn, it is pretty stright forward deal, take about 2 hrs and may need a cheater bar extension to get the c-clip to pop the drive-shaft off if that makes sense. But yeah no need for any special tools or anything. but you will think to your self half way through it that you wished you had a cutting torch and 5 gallons of gas, just sayin'
Old June 15th, 2011, 08:54 PM   #5
Shotgun
Shotgun's Avatar
lol
Old June 15th, 2011, 08:54 PM   #6
Shotgun
Shotgun's Avatar
Old June 15th, 2011, 08:58 PM   #7
MiNi Beast
MiNi Beast's Avatar
what you wanted some damn help well I helped.
Old June 15th, 2011, 08:59 PM   #8
Shotgun
Shotgun's Avatar
This shaft just looks like a clusterfukk in the making.
Old June 15th, 2011, 09:02 PM   #9
MiNi Beast
MiNi Beast's Avatar
why you going to want to use a cutting torch then when it pisses you off you going to want to dump the 5 gallons of gas on it and burn the damn thing.
Bad cv yoke on it?
Old June 15th, 2011, 09:08 PM   #10
Shotgun
Shotgun's Avatar
thats what I'm thinking. makes a bad noise in 4wd.
Old June 15th, 2011, 09:22 PM   #11
MiNi Beast
MiNi Beast's Avatar
common issue and pricey as well.
Old June 15th, 2011, 09:32 PM   #12
Shotgun
Shotgun's Avatar
brother just scored a used one for $100.00.
Old June 15th, 2011, 10:33 PM   #13
MiNi Beast
MiNi Beast's Avatar
hell yeah good deal. now charge him $300 to install.
Old June 20th, 2011, 09:12 PM   #14
Shotgun
Shotgun's Avatar
fixxored, I guess you need grease in there to prevent rust in the CV's it has no cover boot on it at all. Dust fell out when it hit the concrete.
Page generated in 0.26274 seconds with 65 queries
