Wagoneer D44 Bolt Pattern Conversion - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 14th, 2011, 09:16 PM   #1
buzzbrick
That boy ain't right
buzzbrick's Avatar
Default Wagoneer D44 Bolt Pattern Conversion
I'm working on narrowing a mid 70's Wagoneer D44 for use in my CJ, and I'm trying to work out how to get the 5x5.5 bolt pattern. There seems to be 2 ways of approaching this, either using Ford parts knuckles out or Ford hubs on small bearing FSJ/ Chevy small-bearing spindles. My question is this; is there an advantage to either approach? I've also heard that using the Ford parts makes the axle 3/4" wider per side, is this true?
buzzbrick is offline   Reply With Quote
Old June 14th, 2011, 10:06 PM   #2
addicted
addicted's Avatar
Either way works as well as the other and the knuckle out approach is the easiest way i've found. I however haven't heard anything about that way making the axle any wider.
addicted is offline   Reply With Quote
Old June 14th, 2011, 11:21 PM   #3
buzzbrick
buzzbrick's Avatar
Thanks for the help!
Page generated in 0.24401 seconds with 32 queries
