What caster angle? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 13th, 2011, 07:44 AM   #1
orionn
orionn's Avatar
Default What caster angle?
I picked up a axle that needs the caster set and the inner C's welded on.
Does anyone know what the factory caster setting is on a D44 frt axle?
I'm looking for a baseline to start from.
Should I set it to 6-7 degrees or more? My jeep has 4" of lift (springs) and its from a '78 Ford Bronco if it matters.
thx
orionn is offline   Reply With Quote
Old June 13th, 2011, 08:12 AM   #2
Bo's Cj 7
Bo's Cj 7's Avatar
I welded my jeep together at 8 degrees I have read between 6 and 10 at ten steering is slower to react at less than 6 they want to dart from side to side
Bo's Cj 7 is offline   Reply With Quote
Old June 13th, 2011, 08:20 AM   #3
orionn
orionn's Avatar
Thx...that helps alot.
I dont mind it being a little slow to react.
If I remebeer right, its measured along the axis of the ball joints, right?
thx for the info
Old June 13th, 2011, 08:38 AM   #4
Bo's Cj 7
Bo's Cj 7's Avatar
I had my outers off at the ball joints put the housing under my jeep set pinion angle put a steel rod up through ball joint holes and used a angle finder. I cut the welds out of the axle tubes to punkin and just turned tubes in punkin was easier then I thought it would be. Top ball joint behind bottom
Old June 13th, 2011, 09:46 AM   #5
orionn
orionn's Avatar
Thanks...I'll have to rotate the C's, the tubes are freshly welded to the pumpkin.
No biggie though.
One other thing....did you Mig weld the tube to the cast steel or use a stick welder and Hi-nickle content rod?
Old June 13th, 2011, 10:40 AM   #6
Bo's Cj 7
Bo's Cj 7's Avatar
I used an arc welder with Hi-nickle rod 70-18 seemed to take more power than other welding I have done to get it to flow good
Old June 13th, 2011, 10:51 AM   #7
chadcooper55
expert jeep disassembler
chadcooper55's Avatar
if you are saying 7018 is what you used that is not a high nickle rod meant for cast. remember when arc welding cast with a high nickle rod you need to follow different procedures than standard welding.
1- pre heat metal
2- de-stress the weld with a hammer and punch after every rod
3-wrap in fiberglass or build a hot box to let the metal come down in temperature very slowly or it will crack.
Old June 13th, 2011, 11:17 AM   #8
I generally like around 6-7 degrees.
You are correct, that you set it off the ball joint/kingpin axis.
Don't forget to dial in your pinion angle at the same time.
Last one I did was for my toyota, set the knuckles at 7* caster, and pinion 5* up from stock.
Old June 13th, 2011, 11:56 AM   #9
orionn
orionn's Avatar
This is a High Pinion D44 (ford)
If I set the pinion for a double carden joint drive shaft (point it at the t-case output)
Are there any special considerations for the oil level?
One blurb I read was to use a mid 70's F250 cover becouse it has a higher fill plug.
Is there anything else I am missing or tricks I need to know?
This will be driven to and from the trails, across several states at a time.
It needs to last.
thx for all the help everyone
Page generated in 0.32006 seconds with 50 queries
