Explorer Steering column help! - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 12th, 2011, 09:17 PM   #1
Fishwerkes
Fishwerkes's Avatar
Default Explorer Steering column help!
Hey guys. Wondering if anyone has any input on my problem. The steering is "loose" on my lifted Explorer Sport (2000 lift with 3 inch body and 5 inch suspension). Let me tell you that I put in a new rack last year, along with new tie rods (inner and outer), new ball joints (upper and lower) so basically the front end is all rebuilt. I did this because it was all worn out, not because the steering was loose (which it was). This did help, but I have a lot of play in the wheel still. While turning the wheel from side to side (taking up the slack), what I can see is the steering rod, as it goes thru the firewall, moves quite a bit side to side. Is there some sort of bushing at the firewall that can wear? I see the rubber boot, but to save my life I don't get it. Hopefully someone has run into this before and knows my problem (besides the fact I am a total idiot).
Thanks for the input guys!
Fishwerkes is offline   Reply With Quote
Old June 12th, 2011, 10:42 PM   #2
osteologation
Everyday I'm Shufflin'
osteologation's Avatar
http://www.explorerforum.com/
Did you try here?
Or maybe http://www.therangerstation.com
A lot of good info and if anybody has that problem it's prolly popped up there.
Page generated in 0.17849 seconds with 29 queries
