1994 Lifted Ford Bronco Posi Locked 4x4 on Dana 60's 1 Tons $2500 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 11th, 2011, 03:48 PM   #1
sellers_43
Default 1994 Lifted Ford Bronco Posi Locked 4x4 on Dana 60's 1 Tons $2500
If your Looking for a off roadin, Muddin truck, this is your truck! This is a 1994 Ford Bronco, with a 5.0L, 190,000 Miles. It has a 6 inch suspension lift, 3 inch body lift. Dana 60 1 Ton axles front and rear. Gears are welded so it is pozi lock, Hubs in truck. This also has a custom made rear bumper that is used for a air tank for when you are out on the trails. This truck is built for 4x4, but is used as daily driver as well. The only thing that is wrong is there is a crack in the passenger side windshield, a small dent in the passenger side front fender, and a little rust around the rear wheel wells, which is normal on a Ford Truck, a small oil leak. Truck runs good, it has a new exhaust, alot of new parts put on including a new fuel filter, new fuel pump, water pump, tune up. This is a great truck, going to have to travel to eastern this winter so I need to get something better on gas, and trust me, it is killing me to let it go. You WILL be happy with this truck! $2500, truck is located in Adrian, Michigan, you can contact me at sellers_43@hotmail.com
ID:	79930   Click image for larger version
ID:	79931   Click image for larger version
sellers_43 is offline   Reply With Quote
Old June 11th, 2011, 04:31 PM   #2
Dune_Trash17
Dune_Trash17's Avatar
Take trades? If so pm me.
Dune_Trash17 is offline   Reply With Quote
Old June 11th, 2011, 07:39 PM   #3
sellers_43
No, I am trying to get a new vehicle..Sorry though
Thanks for the offer!
Old June 11th, 2011, 07:47 PM   #4
masterbeatty
masterbeatty's Avatar
Dana 50 front 10.25 rear 4.30 gears fyi
Page generated in 0.24421 seconds with 36 queries
