302 V-belt locations - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 10th, 2011, 08:23 AM   #1
amc78cj7
amc78cj7's Avatar
Default 302 V-belt locations
Can anyone give me the order of the belts from the block out for an old-school 302? There is the water pump pulley, alternator pully, power steering pully and I think 2-groove pully on the crank.
A link to a diagram would be nice if anyone has it also. Unfortunately all my manuals lack these diagrams.
I'm not quoting idiots who promote unsafe recovery strap techniques anymore. :miff:
amc78cj7 is offline   Reply With Quote
Old June 10th, 2011, 08:50 AM   #2
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
I have a bunch of old stuff if you want to dig around in them old books.
If I remember right the double is the alt in a lot of those old ones.
Yetti
Old June 10th, 2011, 09:21 AM   #3
Elvis13
IIRC. The water pump is the double belt pulley. I believe there is a triple going between the crank, PS and water pump. Then the outer v on the water pump spins the alt.
the inside belt does this
Water pump ________PS
Crank pulley
The outer belt does this
Alt
Water pump
Old June 10th, 2011, 11:10 AM   #4
amc78cj7
amc78cj7's Avatar
So how many belts total; 2?
Thanks. Putting this 302 together and it had not belts. I went to O'reillys and they sold me 4 belts for the setup. I was like "I don't think there are enough pulleys for that". One of them is so small it wouldn't even fit between the water pump and crank...
Jeff
Crank pulley
Alt
Water pump
Old June 10th, 2011, 11:11 AM   #5
amc78cj7
amc78cj7's Avatar
Let me know if you'll be around this afternoon and I'll stop by. A rat just peed on my shirt at work and I'm leaving early to change. The smell is driving me crazy.
Old June 10th, 2011, 12:09 PM   #6
Elvis13
Jeff
Yes i believe so. I know for a fact there is one belt from the alt to the water pump.
I do know that truck has been hacked together multiple times. No guarantees that it's right but it does work.
Page generated in 0.19158 seconds with 41 queries
